Question about Krups Nespresso 554
I have a Krups Nespresso machine which is leaking internally. Water appears to be running down the pipes, which can be seen when the tray is taken out. How do I open the machine to check seals, etc?
5 Suggested Answers
SOURCE: Krups type 897, nespresso: Water leaking
I swaped the hose around.
The o-ring at the element end is bigger and can be held in properly by the clip at the pump end. The bracket/clamp at the element end holds in the smaller o-ring sufficiently.
Posted on Oct 14, 2008
  • 14 Answers
SOURCE: Krups Orchestro Leaking
the water is clean or its coffee? if is clean, then replace the seal from the water tank. if is coffee, then replace the valve under the mecanic group.
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: Error Code 9 on a Krups XP7240 Expresso machine
After I changed piston sealing I get the same error 09. It was caused by missing connection to the thermoblock temperature sensor. In my case both connectors for thermocouple were cracked. They are located directly on the body of thermoblock, below two fuses, covered by rubber housing. After I solder them again on the position error 09 disappeared. Unfortunately it is necessary to open at least front panel of the machine. Moreover I tink that there is also important to save polarity of those two cables.
Posted on Aug 07, 2009
SOURCE: Krups XP2070
thanks for the fix, are you saying to replace the clear rubber O-ring with a thicker rubber piece?
Posted on Oct 25, 2011
Leaking water when not in use
possible of leaking internal pipe may need to change /or drip tray to full also cheak water tank and see if it leaks
Mar 28, 2016 | DeLonghi DE LONGHI EN95S M.CAFFE CAPSULE...
Krups FNA2 doesn't draw water!
If it sounds like a pumping noise but louder then it may mean that the pump is bone dry and needs to be primed. You need to find an imaginative way to force water into the socket that the tank engages with. A clear hose of the correct size with water already in it and then press the button and blow into the other end of the pipe. Once the valves are immersed in water it should start to function.
Dec 18, 2013 | Krups Coffee Makers & Espresso Machines
Where can I get spare parts for the Krups Nespresso Citiz XN. specifically the Drip tray and the base it sits on
Why don't you try "Krups" ? I would think this would be the best place to start. Ask them if they stock the spares and if not where they are available.
Feb 24, 2012 | Nespresso Coffee Makers & Espresso...
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
Nespresso Essenza D100 leaking water while brewing
Sounds like a gasket or seal gone or a split pipe.
If it's still under warranty - take it back for free service or replacement.
If you do have to attempt DIY, then a clear silicone sealant may save you the price of expensive gaskets.
Be very careful when taking apart - take notes or photos as it will help put it back together !
I usually put related sub-assemblies together with their screws in separate pots.
Aug 11, 2009 | Nespresso Essenza D100 Espresso Machine
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Krups type 897, nespresso: Water leaking from top of pump. I've opened the back of machine and found that when the pump starts the water is shoting out at the join to the clear hose. The leak reduces when...
Oct 11, 2008 | Krups Small Appliances Espresso Machine
Leaking water, does not close
I had the same problem with the nespresso krups xn20 machine. After calling the Nespresso service desk they substituted free of charge the water tank, which has a little valve with seal at the bottom. It turned out that the problem was not the seal of the water tank, but the seal of the machine (onto which the water tank is installed).
I solved the problem by using Teflon tape (same type as that used to connect for water pipes) on the water tank, applying it at the appendix which goes into the machine.
It's been working ok since then (couple of days). The only problem could be the wearing-off of the tape after some time (you will have to reapply it).
Apr 17, 2008 | Nespresso C100B Essenza Single-Serve...
Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Aug 20, 2007 | Nespresso C190 Espresso Machine
Krups Nespresso 554 Logo
122 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
