Question about Crafts & Hobbies
Harley davidson road king mega block 9770 instructions
  • 2336 Answers
SOURCE: shocks
The Road King shocks are air adjustable via an air valve located on the right side of the bike just above the rear tire. Your Harley Davidson owner's manual will tell you what the shocks should be pressurized to depending upon the load on your bike (for instance - if you'll be carrying a passenger - the pressure should be a bit higher than it would be if you were riding solo). Don't even attempt to read the pressure unless you have the specialized hand pump that is used to pressurize the shocks. You can purchase this from Harley Davidson or via a third party online. The valve is a typical bicycle / auto air valve - but ... DO NOT attempt to pressurize it with anything but the specialized hand pump. Using anything else will risk over pressurization of your shocks and that's not good. The shocks hold a very small volume of air at relatively low pressure levels - so the hand pump is a must have.
Posted on Nov 10, 2008
SOURCE: shift pattern
1st gear all the way down (toe shifter, not heel). Lift up N,2nd,3rd,4th,5th-6th(if applicable)
Posted on Nov 17, 2008
DJ_MAX1369
  • 119 Answers
SOURCE: fuel pump?
the fuel pump for your 2000 fuel injected road king is located in the fuel tank. you will have to remove the speedometer housing, by first removing the seat, then remove the one small screw near the seat that holds the speedometer housing in place, also remove the small screw at the front of the speedometer housing and lift the housing off the tank and disconnect the wiring that goes to the back of the speedometer. there is a large oval shaped gold in appearance plate on top of the fuel tank. this plate is what the fuel pump is mounted to.
Posted on Mar 31, 2009
  • 269 Answers
SOURCE: how to replace fuel filter on harley davidson 02
I am having problems viewing the reply but if you have a FLHRCI then to replace the fuel filter you will need to be prepared to put some time into it.
First remove the console off the fuel tank, one nut below speedo and the phillips screw lower close to the seat. You will have a disconnect on the top left side of the fuel tank to disconnect. Then disconnect the vent tube from the tank with a gentle pull & twisting motion. Now the fun part there are ten torx T20 screws you need to remove, but first you must go buy new ones along with the gasket and fuel filter kit. DO NOT reuse the screws. Now for whatever reason they call this piece a canopy, go figure. Once you have your parts go ahead and raise the canopy slightly and twist it to the left a little. Now this can be tricky because there is a spring loaded hng to work here, be care not to over stress any thing. Then you can begin to pull the canopy and components from the tank. You will be limited by the convoluted tubes (hose) attached as to how far you can raise the canopy, if you remove one be careful as where they attach is plastic and breaks....easily sometimes, then you need a $350 part.
Next read and look at the diagrams that come with your new fuel filter to install it. Once done carefully reverse the canopy removal process and tighten the canopy bolts in cross pattern o somewhere between 18-27 in-lbs. Hope this helps.
JP
Posted on Aug 15, 2009
SOURCE: Need the Instruction book (1) for Mega Bloks
I have book #1 but not #2 - maybe we could copy each other?
Posted on Nov 20, 2009
How do I remove fork lock housing?
Hi Anonymous, for more information about your question please visit the website below. Good luck and have a nice day.
Harley Davidson Manuals Mark Workshop
Ign Switch mp4
Apr 04, 2013 | 2006 Harley Davidson FLHRCI Road King...
I'm trying to install an air ride solo seat from a police Road King on a Road King, I can't seem to find any reference on installation. Can you help?
I'm sorry but I'm not familiar with the seat you are working with. If the seat is made by someone other than Harley Davidson, they may have a website at which you can get installation instructions. If they are not posted, contact the company via e-mail or telephone and ask for installation directions.
Good Luck
Steve
Aug 20, 2010 | 2002 Harley Davidson FLHR - FLHRCI Road...
Need the Instruction book (1) for Mega Bloks Harley Davidson road king
Sep 19, 2009 | Mega Bloks Toys
Hand controls
Pay Harley to do it. I did it , but would never do it again.
Nov 27, 2008 | 2006 Harley Davidson FLHR Road king
Crafts & Hobbies Logo
81 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
