Question about GE 27GT271 TV
I have a GE remote monitor XS stereo tv, model# 25gt522. Today I accidentally hit the channel button on the tv, it turned my directv off and I cannot get it back on. Also, I have no remote for the tv. What do I do?
    Problem Solver:
  • 6 Answers
Turn on your tv by the power button
the direct tv call them for a remote
Posted on Jan 02, 2014
SOURCE: WIll not work with Comcast, DirecTV, DishNetwork Remotes
Hello! I just got my Directv remote to work with my GE tv. I started by trying code 11922, and when that didn't work, I followed the Directv instructions to find a set-up code manually. After I followed the instructions below and doing it about 6-8 times, it started working! (So I guess the code 11928 - 11930 might work?) Good luck! I'm still having problems getting the "video" setting to work to switch inputs, but I'll keep trying...
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on Oct 26, 2008
tvguy171
  • 106 Answers
SOURCE: my ge tv digital ready?
Your TV is NOT digital ready. IF you do not have cable or satellite, you will need a converter box. If you do have cable or satellite you have nothing to do or worry about as the cable or satellite box will automatically do the conversion for you. Hope this helps
Posted on Dec 20, 2008
SOURCE: TV locked on channel 3 and have no remote
Thats EXACTLY what happened to our tv!
Ours was originally locked on channel 4 but I left it unplugged overnight and now its oddly stuck on channel 3.
The only thing I can think of to do is try to search for/buy a remote that will work on the tv to bring the menu up again. I don't know how to manually reset it or do anything.
Posted on Jun 17, 2009
SOURCE: I have GE XS Stereo Commercial Skip Model 27GT619
  1. On the front of the TV press the MENU button to display the MAIN MENU.
  2. Scroll through the choices using the VOLUME up and down buttons
  3. When positioned on the selection you want press the MENU button again.
  4. The first SETUP screen displays, asking you to select a language.
  5. Scroll to the desired language ENGLISH, FRANCAIS or ESPANOL and once it is highlighted in green press the MENU button to make finale selection.
  6. A SETUP screen appears asking if you would like the TV to search for all channel
  7. 1. Yes
    2. Skip this step
    3. 0 Exit
  8. Complete the SETUP routine or skip any of the steps and return to them later.
This information is from the User Guide that came with our set. Good Luck.
Posted on Jul 01, 2009
  • 541 Answers
SOURCE: My GE tvwon't turn on with tv button or remote-just clicks
Most likely there is a problem in the power supply circuit inside the set. This probably would not be cost effective to repair. Thanks
Posted on Oct 29, 2009
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
How do I put the GE remote xs stereo monitor into input mode without the remote?
A good universal remote to use with that monitor is the RCA RCRN04GR, available at WalMart. I recently bought a 25" GE Remote Monitor XS Stereo from a Days Inn that was replacing all of those monitors with Flat Screen TV's. When I got it home I found that it would not go to channel 4 which was default with my COX Digital Cable Box. Channel 3 is the default channel on the monitor, so I ran an AV cable from the cable box, disconected the coax and hooked up the AV cable to the back of the TV and that solved the problem. I hope that answer was helpful.
May 31, 2010 | GE Televison & Video
We have DirecTV and is is on channel 4. My
Use the tv remote to put the tv on ch 4. Use the direct tv then to select channel of the direct tv box. The box is broadcasting to the tv on ch 4. Also check that tv is on correct input . Again use the Panasonic remote to select correct input. If this does not work call direct tv for assistance.
Dec 03, 2009 | Panasonic TC-32LX60 32 in. LCD Television
  7. 1. Yes
    2. Skip this step
    3. 0 Exit
Jun 11, 2009 | GE 27GT271 TV
I have Directv I don't know what step I am missing when I turn on the tv, then turn on the dvd put dvd in but somewhere there I am not doing something because when I hit play the directv is still on. The...
The DVD player is plugged into one of the television's input channels, and the satellite is plugged into a different channel. You will have to take either your television's remote (not the staellite remote) or find a button on your television itself, and press a button that says "input," "source," "video," or "TV/VCR" and find the correct channel on your television that corresponds to the DVD player. If you give me the model # and manufacturer of your television, I can tell you exactly which button to press.
-Tha mp3 Doctor
Feb 21, 2009 | Protron PD-800 DVD Player
My ge tv digital ready?
Dec 20, 2008 | GE 25GT240 25" TV
Switching Input on GE Stereo Monitor
I tried for a while to get my dvd to work. I went to the menu, from my universal remote that totally works. Went to the menu, then channel set up, and switched the VCR1 channel to 00Enabled. When I want to watch a dvd I press 00 for my chanel and it works. I hope this helps all of you.
Dec 13, 2008 | Televison & Video
    1. for Televisions
Oct 18, 2008 | GE 24GP653 24" TV
Directv DVR vs Tivo
I found the manual for that model online, and according to it, the "Live TV" button should function exactly the same way your old Tivo did.
If it's not working correctly, you may want to contact the manufacturer, assuming it's still under warranty.
Aug 06, 2008 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
GE 27GT271 TV Logo
183 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
