Question about Sewing Machines
Mega quilter binds thread under fabric
When I sew - even at slow pace - the thread knots and binds under the plate
If you have to manually set the tension on your bobbin, your tension may be too loose or too tight. When my bobbin is full of thread the tension has to be stronger than when it is almost empty. So tight when it's full and loose when it's nearly empty. I hope this helps. If this doesn't work try using a air can to blow out the dust in your bobbin casing and make sure the bobbin doesn't have any burs. It needs to be wound smoothly. Also check for thread hangups in the bobbin casing area. Also you may want to completely re-thread your machine.
Posted on Jan 02, 2014
SOURCE: sudden knotting under fabric
I have an Elna 2005 machine and had a similar but opposite problem whereby the tension up top was too tight - thread wouldn't pull smoothly. I found adjusting the feed dog lever slightly helped the stitches a lot, even though the needle tension up top is no better. Hope that helps! :-s
Posted on Oct 29, 2007
bargainbox
  • 1388 Answers
SOURCE: Thread bunching and knotting under fabric
The thread does pass over the top of the bobbin case to form a stitch, perfectly normal, whether front or top loading bobbin.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
bilabon
  • 46 Answers
SOURCE: Bobbin continues to pose problem - knotting thread underside of fabric,
In 99% of all problems with "bird's nesting" or "knotting" it is an issue of the thread coming out of the take up lever (at threading guide #3) (from the spool; through the first thread guide at #1 down to #2 and up to # 3) when the thread comes out of the take up lever, the machine can not regulate the thread and it floods the machien with thread and wraps itself around the bobbin case. OR! Your tension is too loose. Raise it. Your machine should preform perfect at tension #4 unless you are using speciality threads or fabrics.
ALWAYS be in the habit of threading your machine with presser foot up so that while threading between paths 1 and 2 you are certain to have the thread pass throught the tension disks.
This will happen on a $50.00 machine or a $5,000 machine. The thread needs to be regulated.
USE GOOD THREAD!
Thanks,
Bonnie
Posted on Oct 30, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
louislevel_2
  • 374 Answers
SOURCE: thread clogs up bobbin and knots up thread on back side of fabric
hi there,
well, common problem when you didn't acquired right set up of tension and clean feed dog,bobbins,shuttle race.on figure right bobbins winding.d329aa1.jpgset up counter clokwise thread rotation, set dial tension on #3 to #4, dial stich to # 8 to #12
only on cotton fabrics,others fabrics such as silk..etc,gradually adjust tension fine the smoothest adjustment,
on fig,thread looping top side threading50302ec.jpg follow threading so you can have fine sewing.also clean under bobbins from chips fabric and dust.have a nice day,don't forget to rate my fix,ythanks a lot
Posted on May 16, 2009
My nedle on my husqvarna mega quilter will only pick up the bobbin thread through one thickness of fabric and not through all three layers. Suggestions?
Try a brand new needle. A dull or bent needle will frequently not pick up bobbin thread. Also, be sure you are using a needle type that is suitable for the thread and fabric you are sewing, ie if you are sewing woven fabric, use a sharp needle, not a ball point or jersey needle.
All About Needles
If you are still experiencing problems, it could be a timing issue. Take it for service.
Oct 25, 2016 | Husqvarna Sewing Machines
When using the button hole attachment, my fabric is not moved forward by the lower plate and thread gets caught up under that bottom plate. How do I fix this
Perhaps you have the stitch length set too short (close together) so the thread under the fabric is building up into a knot and then hangs up in the space under the needle plate. Try lengthening the stitch length and do some tests until you get it where you want the buttonhole to look.
How to Make Buttonhole on Your Sewing Machine Sew4Home
How to sew buttonhole with an old machine
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Jan 30, 2016 | Sewing Machines
Why is the fabric not feeding forward when stitching
on the front of the machine there is a lever/knob that sets the stitch size
if it is in the middle position ,the teeth will just go up and down and not back and forward
check that setting
it is used to seal of the threads when starting to sew and when finishing
start the sew for about 1/2" then reverse the feed then go forward again to complete the sewing
at the end of the sew do the same thing again before cutting the threads
this locks the threads as a knot so that the seam will not come undone
Sep 27, 2015 | Sewing Machines
I think I need a new bobbn case as the thread keeps binding up under the plate
Make sure your needle is threaded correctly and that the needle is not old or blunt.
make sure that the thread and needle size are compatible with the material you are using.Or check with manufacturer.
Apr 21, 2014 | Simplicity Quilter's Classic SW240...
Sews 1/4" and then sews in place
1) remove upper and bottom threads. Try sew without threads.
Is fabric transported corectly?
NO:
- Drop feed dog button is OFF
- Dust under stitch plate
- Transporter malfunction (must be taken for a service to the BERNINA dealer)
YES:
- Upper or bottom thread jammed
- The upper thread tension is too tight.
- Wrong needle used (probably small ...)
Nov 20, 2013 | Bernina Bernette Deco 600
Mega Quilter tension inconsistent
change the needle--needle must be correct one for fabric sewn
adjust the top tension--make sure there is no lint or loose threads
in the top tension dial
also clean under the needle plate & in the bobbin area for lint or loose threads
make sure the bobbin is inserted correctly--some bobbins only go one way
Apr 18, 2012 | Sewing Machines
Husqvarna mega quilter is bunching bobbin thread when quilting. Top thread looks fine. I have tried adjusting tension. what should I look for?
try a new needle
clean these areas,,under needle plate,,,bobbin area
check to make sure the thread has not come off the thread take up lever
Aug 02, 2011 | Husqvarna Sewing Machines
I have a Euro-Pro 7500. I can't seem to sew a straight stictch without the thread binding up from the bottom of the material.
Do you mean the thread knots and loops up under or over the fabric? If so it sounds like you need to re-thread. You may have not put the thread into one of the tension wheels correctly. Keep the presser foot up when you do it.
Jan 25, 2011 | Euro-Pro 7500XH Mechanical Sewing Machine
Sudden knotting under fabric
Jul 01, 2007 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
