Question about AT&T LG CU720 Cell Phone - Silver
Slider my phone all of the sudden became very difficult to slide open and closed and it looks like something came loose and is stuck in the back between the slider. i went to the store and they said to call and i should get a free one cuz its under warranty, but when my mom called some lady said no. so i called back and a guy said yes, but if i send it and they see that it's physical damage then they'll bill me $210 which is total bs. i cant decide if i should take the risk and send it...
  • 1,889 Answers
Take pictures of the phone and,what; where; the trouble area looks like; is. Then send it.
make sure the photos are dated.
Posted on May 20, 2009
Sliding rear door stuck in open position
Is it a power slider? What side is it? If it's a power slider it's possible the fuel door was left opened when the door was opened? If so, turn off the power slider switch on the left side dashboard (left of the steering wheel), then manually close the door. Make sure the fuel door is closed before turning it back on.
Jul 26, 2013 | Honda 2012 Odyssey EX-L
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
2012 HONDA ODYSSEY DOOR STUCK OPEN
It's possible the fuel door was left opened when the power slider opened? Turn off the power slider switch on the left side of the dash board (left of the steering wheel), then manually close the slider. Close the fuel door then turn the power switch back on. If it continues to jam, turn off the power switch again and open/close manually until you can get it to the dealer.
When i slide up my mobile,it doesnot work..
what kind of phone is it ? you need to buy the tool to open it. most phone that slide have a wire that could come off when you open and close to much so you need to put it back were it belongs. like in this picture! if you look close. http://www.instructables.com/id/Disassemble-your-Samsung-A737-slider-phone/
Nov 09, 2010 | Cell Phones
My phone became harder to slide then eventully stoped sliding
Same problem here. Mine wouldn't close. Take out the battery. When the screen is in the open position there is a hole on each side where you will see the hole for the screws. Hopefully one is still intact so you can compare them. Just need a tiny screwdriver to put it back in and tighten it up. Slides without problem now.
Jun 12, 2009 | Sony Ericsson W910i Cellular Phone
I cannot close the slider of my celphone sony ericson w580i?
if its slid open n wont go back something isnt on the track properly. try to push it down but do not force it as that is classed as physical damage. u may be able to return it under warranty but be careful u dont damage it first. otherwise take it to a cheap asian repair shop- (nopt racist, they usually r the cheapest) and get it fixed mate.
May 05, 2009 | Cell Phones
Phone stopped working suddenly
This sounds like a flex cable issue. You will need to have a tech examine the device to see if the flex cable needs replacement.
The flex cable is the ribbon cable that connects the screen to the rest of the electronics and allows the slider mechanism to slide and have the device maintain proper electrical connection. After two years it may very well be worn out.
Dec 02, 2008 | Samsung SGH-t629 Cellular Phone
New Slider Does Not Work - key lock too!
I Would send the phone back, you could be damaging it even more.
Sep 21, 2008 | Samsung SGH-D600 Cellular Phone
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
AT&T LG CU720 Cell Phone - Silver Logo
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
