Question about Sharper Image The 4-In-1 Salad Spinner Mandoline Slicer
Broken salad spinner - Sharper Image The 4-In-1 Salad Spinner Mandoline Slicer
How do I remove the plunger for washing?
The plunger on mine cannot be removed. I just checked it to make sure. If you remove it, you have broken the unit. Just rinse with water. The plunger should not get dirty of used properly. A rinse under running water is enough.
Jan 28, 2015 | KitchenAid Salad and Fruit Spinner - White...
How do you make salad?
http://en.wikipedia.org/wiki/Salad_spinner
the spinner removes water from lettuce leaves to allow oil (salad dressings) to stick to the leaves. Spin salad then put in a bowl and mix with a salad dressing .
Nov 02, 2014 | Home
Can't lock down my kitchen aid salad spinners handle
You can't the product sucks worst salad spinner on mkt.way over priced
Apr 08, 2014 | KitchenAid Green Apple Classic Salad...
How should I dry lettuce if I don't have a salad spinner?
I don't have a salad spinner at home. All I do it rinse the lettuce, leave it basically "standing up" inside of a collander and let the water drip off. If I don't have enough time to leave it til it drys on its own, I sometimes shake it out and then wrap in it paper towel for a few minutes.
Jul 11, 2013 | Home
Is it true that it isn't good to put mushrooms in a salad spinner?
I haven't heard that but I'm guessing the myth has more to do with getting mushrooms wet. Some chefs say that if by washing mushrooms off with water, it rids them of some of their earthy flavor. Many chefs at nice resaurants simply rub the dirt off of mushrooms, not soak them.
Jul 11, 2013 | Home
I've got mould in the little squares of my salad spinner. What's the best way to clean it?
I'm guessing that your salad spinner is made of plastic. If you don't have a dishwasher with a hot water option, I would fill your sink with very hot soapy water and let it soak until the water cools. By then, most of the mold should have come off and you can simply rinse it.
Jul 11, 2013 | Home
Where can I buy a salad spinner? It'd be a bonus if it had a brake in it to stop the spinning.
With a brake!! enjoy :)
http://www.target.com/p/oxo-salad-spinner/-/A-628331
Jan 14, 2013 | Home
What does a salad spinner do?
A salad spinner washes and takes away extra water from the lettuce/spinach/etc. The lettuce spins around which creates a centrifugal force. This force gets rid of the water.
Jan 14, 2013 | Home
How to use salad spinner
Just plug it and press the power on button.Make sure that you plug it in the correct power.
May 18, 2009 | Food Processors
Sharper Image The 4-In-1 Salad Spinner Mandoline Slicer Logo
89 people viewed this question
Top Sharper Image Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Sharper Image Kitchen Appliances - Other Expert? Answer questions, earn points and help others
