Question about Toys
Caterpillar 475 c15 head bolt torque specs are ?
  • 25 Answers
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Posted on Mar 17, 2009
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
polarcycle
  • 1392 Answers
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Posted on Aug 16, 2009
outdoorsman5
  • 631 Answers
SOURCE: head bolt torque specs for 2000 dodge neon 2.0 SOHC
I have the specs and diagrams. If you want me to send them to you, give me your email address. Outdoorsman592003@yahoo.com
Posted on Sep 05, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
I need data for cat engine test spec 0K1091 please
need to notify caterpillar service for that type of information or a dealer
Products Services North America
Aug 26, 2016 | Caterpillar Cat C 11 C 13 & C15 On Highway...
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Cylinder head to engine block torque sequence and ft lbs
    images for Cylinder head to engine block torque and ...
    More images for Cylinder head to engine block torque and sequence
    Small Block Chevrolet V8 Engine Specs ' Torque Specs ...
    boxwrench.net/specs/chevy_sb.htm
    their specs. Click Here! 3/8 Connecting Rod Bolt, Engine Oil, 45 ft-lbs. 11/32 Connecting Rod Bolt, Engine Oil, 35 ft-lbs. Cylinder Heads. Engine oil. (blind hole).
    [PDF]
Nov 29, 2015 | Cars & Trucks
I have a 79 gmc c15 royal sierra heavy half it has the 12 bolt pattern on the rear end cover & I'm needing the torque spec for the bolts for the cover
These don't need to be very tight, same as trans pan bolts or maybe a little more. Don't know exact spec, but perhaps 8 ft. lbs.?
Mar 28, 2015 | GMC Cars & Trucks
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
Adjusting turbocharger for caterpillar c15....boost gauge does not get above 8psi
Most turbos are pre set. if you don't know what you are doing you can ruin it. I would look a little closer at the waste gate not performing properly.
Aug 22, 2013 | Caterpillar C15 Acert Engine Wdisplay...
Torque spec
Head bolt torque is 32 ft.-lb. (43 nm)
Head cover bolt torque is 7 ft.-lb. (10 nm)
Mar 25, 2010 | 2000 Yamaha Royal Star Venture
Toys Logo
44 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
