Question about Hobby King Cyclone-E All Moulded Composite Hotliner 2000mm ARF
Hobbyking cyclone e problems - Hobby King Cyclone-E All Moulded Composite Hotliner 2000mm ARF
Does anyone know where/how I can find a replacement battery pack without having to buy a whole new car.
most hobby shops have battery packs for rc cars.. but if you cant get it there, you can buy it from ebay,amazon,hobbyking or newegg or similar sites. the web is full of sources for battery packs.
just remember shipping may be slow from some since lipos over a certain size is shipped by ground
Aug 10, 2015 | RC Thunder Tumbler Rc Car
2000 buell cyclone fell over and won't shift
Bent shift fork - requires internal service work. Costly and time consuming. Don't let em fall over to avoid this sort of problems with ANY bike.
Apr 01, 2013 | 2000 Buell M2 Cyclone
I can not get the unit to turn on. Is it possible to have killed the battery?
Here is the link to the manual. I have this camera that I use on an RC airplane.
http://www.hobbyking.com/hobbyking/store/uploads/57465344X43556X26.pdf
You can kill the battery but I think that you just need the manual. These are hard to use because there is no real feed back to the user. These give OK video and are almost bullet proof.
Regards Outback
Apr 25, 2011 | BrickHouse Security Mega Mini Spy Camera...
I am looking for the connector & Terminals
hobbyking.com -> battery connectors
Apr 04, 2011 | Toys
Tippmann a5 cycles just not fast
The cyclone is supposed to feed at least 15 p/s if you are having that problem I would take apart the cyclone make is clean, you would not believe how much paint can get in there. I would check the hose and after that the o-ring on the cylinder piston. Another thing that might be messing the cyclone is the speed on the marker or the valve itself not sending the amount of CO2 or air to the cyclone. I hope this helps.
May 02, 2010 | Tippmann Cyclone Feed System
Bad odor, I cleaned my dyson with water and vinegar but when I
You can't remove the purple top - that'll permanently damage the cyclone.
Blow the cyclone out from the bottom with a leaf blower or an air compressor. DO NOT use the machine whilst you can still hear water in the cyclone - you'll bust the motor. Never submerge the cyclone in water again either, you'll just have the same kind of problem again :(
Jun 11, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dirt and hairs not going into cylinder
It's not the filter that's the problem.  Air should go first to the cyclones, then to the filter, so the filter catches only those finest dust particles that are not trapped in the cyclones.  The most likely cause of the problem is that the cyclone pack is not properly seated, with the result that at least some of the dirt-bearing air is going directly to the filter rather than passing through the cyclones first.
Apr 18, 2009 | Dyson DC11 All Floors Bagless Canister...
Cyclone air pre-cleaner
What has got to do cyclone air pre-cleaner with Toyota. Explain problem in detail.
Jul 22, 2008 | 2007 Toyota FJ Cruiser
Hobby King Cyclone-E All Moulded Composite Hotliner 2000mm ARF Logo
139 people viewed this question
Top Hobby King Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Hobby King Toy Expert? Answer questions, earn points and help others
