Question about Dell Computers & Internet
PowerEdge 2900 not detecting 2 sata hard drives installed
  • 1,511 Answers
If you have only One Drive the computer is telling you that the One Drive has "TWO" partitions. The main partition has the OS and Programs, and the 2nd partition is for reserve/OS backup data.
Posted on Jan 29, 2014
  • 159 Answers
SOURCE: Adding DVD to Poweredge 2600
PE2600 has lots of spare power (unless you are already using all 6 SCSI drive bays) ..
You can fit 3 x SATA drives in the space where the (useless) tape backup unit is sitting [you can even buy a 'proper' enclosure = Icy Dock MB453SPF or I think the SNT-2131 will fit ] .. and you can split the power off the Tape drive (4pin) power socket ..
I've not found a DVD burner (only a combined DVD reader / CD burner = TS-L462C) .. however if you have a spare IDE port you should be able to use an external unit [you will need an e-ide cable & enclosure for the drive]
Posted on Feb 09, 2009
  • 2692 Answers
SOURCE: dell poweredge 1600 sc XP install
I believe you would need to install the Serial ATA card driver before installing windows. When you first start Xp it asks if you have any ATA drivers that need to be installed first.    My guess,since it is used, that you have not the driver for that card?    Give us the make and model of that card and we can help look for the driver,or take it out all together and use an IDE hard drive.
Posted on Feb 19, 2009
  • 148 Answers
SOURCE: Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Posted on Feb 26, 2009
SOURCE: Dell Power Edge 2900 couldn't read all memories
online payment Gateway Integration, Erp Software Development, Integration of website, Maintenances of Software, HMS, DMS, Bulk Emailer, Bulk Rss Feed Submitter Software and many more Erp Product on er.amish@gmail.com or visit my website :http://java2all.wordpress.com/software-products/
Posted on Apr 03, 2010
SOURCE: Dell PowerEdge 1400SC Can not locate hard drives or partition
You need to download Dell's Storage Managment ISO file, create a CD, boot the system with this CD and set up the array. This will also give you the option to install the O/S with no user input.
Posted on Jul 16, 2010
Why the hard drives are not detected, and when accessing controller from the BIOS no hard drive found only DVD drive ?
You need to access the PERC system at bootup.. Much easier to use a SATA HD and not use the PERC controller.
Aug 04, 2014 | Dell PowerEdge T420 Server
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
Second hard disk drive not detecting
make sure you have the second hd set to slave
Jan 31, 2013 | Dell POWEREDGE 2900 Server
Problem to install poweredge r710 can nor detect sata hard disk
That is an impressive piece of kit. Is it under warranty ?
You should probably have it professionally serviced but you can always check whether it detects a known good drive. You can also test the suspect drive in another system.
Before you do anything ask yourself: What changed last (or recently)? There find you will that which disturbs the force.
Make sure that the connectors are all fully inserted. This means both the power and the data cables. Try different cables and a different power plug.
Sep 01, 2012 | Dell PowerEdge R710 Server (D263K)
PXE-E61 failure while booting Dell poweredge 2900 server
Its a Network boot process ( Earlier Boot Rom ) Disable in BIOS setup or Ignore it, install OS and use server.
Apr 06, 2012 | Dell POWEREDGE 2900 Server
I am installing window xp professional but there is no hard disk to detected to install.. and there are 2 hard disks attached
If your hard disks are SATA hard drives then the XP Pro installation cannot detect these SATA hard drives because the installation CD does not include SATA drivers.
To install Windows on SATA hard drives, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
May 15, 2011 | Computers & Internet
How to install windows server for desktop
You must check if your bios detect your hard disk. check also if you r hard disk is sata and if it is on master jumper. see also it the HDD sata is enable in your bios. if all of this is ok, it must find the HDD. If not, you need to change your HDD.
Feb 09, 2010 | Dell PowerEdge 1600SC Server
How to install sata hard drive on dell power edge
You have to "FDisk" or "Partition" the Drive before Windows will see it.
XP - Goto: Control Panel | Administrative Tools | Computer Management | Disk Management
Vista/Win7 - Goto: Control Panel | System and Security | Administrative Tools | Computer Management | Disk Management
You will see hopefully both Drives... Highlight the New One... Create a New Partion by Right Clicking or use the Pull Downs. It will ask size etc... use the defaults.
Next Format the Drive - Select the Drive again...Right Click Format using Quick Format to save time and you should be set.
Jan 02, 2010 | Dell PowerEdge 1600...
I have lost the scsi drive on a dell 1600sc and would like to convert to sata. During boot up the sata controller is reconizing the 2 hard drives but, come but with "no primary drive found"
The best thing to do is reinstalling SCSI, SATA can only manage two disk per channel on this server, and the data transfer time is longer.
If you set SATA, check jumper settings, that is probably reason why you get no primary drive.
Also check bios settings , do hdd auto detect and save in bios if you want to use sata.
If instead you want to go back to SCSI, download the drivers from the link below.
Download page from Dell.
Mar 03, 2009 | Dell PowerEdge 1600SC Server
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
