Question about Seagate Expansion 1 TB USB 2.0 Portable External ST910004EXA101-RK Hard Drive
Seagate blue light flashing
Had my Seagate for a few months now its not working, my laptop cant pick it up and the light is flashing. got to much stuff on there to lose it all. whats up with it??
    Sergeant:
  • 302 Answers
Just a thought.......see if it's got a reset switch. It might be a TINY little thing
Posted on Jan 02, 2014
Benimur
  • 6966 Answers
SOURCE: seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 17, 2008
SOURCE: My Seagate FreeAgent Pro 500GB
After all of the countless "solutions" I've come across online and otherwise, NONE of them worked. Absolutely NONE. However, there was one common thread amongst all of them that rang very clear with me. Whether it was overheating or faulty parts altogether, I found the solution. Rather than pay HUNDREDS of dollars to have some 3rd party recover my data (like SeaGate tech support suggested I do), I ripped open my SeaGate enclosure, took the hard drive out and simply slipped it into a new, generic enclosure (CoolMax 3.5" External Enclosure to be exact). That cost me all of $20. Problem solved!!!!!!!!!!!!!!! How less stressful is that for you????
Posted on Sep 15, 2008
SOURCE: No Power to my Seagate FreeAgent Pro 500GB
HI I AM SHAHBAZ GILL FROM GREECE ..I HAVE PROBLEM FOR THIS .PLZZ HELP ME................ Seagate free agent desktop 500 gb........ directory is corruted ..
Posted on Oct 05, 2008
SOURCE: The light on my Seagate freeagent go flashes
I had similar problem recently. I noticed that I had forgotten to connect the power supply cable to the USB hub, to which my FreeAgent Go was connected to, after I had connected all my USB devices to my computer's USB ports (after I had disconnected everything from my computer in order to isolate another issue). Reconnecting the power supply cable immediately stopped the flashing light and windows recognized the drive.
Don't know how you are connecting yours to the computer i.e. via a USB hub or directly to the computer's USB port. Note that my FreeAgent Go drive requires both USB connectors connected to the computer (or to USB hub). Two USB connectors are on one end and the other end of the cable is connected to the drive/docking station.
Hope this helps.
Posted on Aug 29, 2009
bob_computer
  • 3153 Answers
SOURCE: seagate 1tb external hd just beeps
You may want to open the drive and check the internal connections first to make sure none came loose after you have powered it down.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. this is a real hard drive and knocks and bumps can quite literally kill them.
If a drive is CLICKING after an accident there is a very strong possibility that it is dead or dying. This is known as the "click of death".
Posted on Sep 07, 2009
Seagate desktop expansion Xbox 360 hard drive format problem
Should work. Xbox uses FAT32, the same as Windows XP, Vista, 7 and 8 can all read it. When plugged into the computer can you see the disk in Disk Management?
Right Click Computer > Manage > Disk Mangement
Jan 29, 2013 | Seagate Computers & Internet
My seagate 1TB external hard disk (the little compact one) cant be read anymore. Was working fine a couple of days ago. The lights on top are flashing constantly. After the drive is plugged into the...
Right click "My Computer" >properties> hardware> device manager. Expand "disk drives". Right click your seagate drive and click uninstall. Reboot your computer; the drive should automatically be reinstalled.
Feb 10, 2011 | Seagate FreeAgent Pro 1TB External USB...
It's a Seagate FreeAgent 500GB, serial number 9QM415RM. It runs perfectly (can hear humming) but my laptop isn't picking it up.
Access the manufacturer's web-site:
http://support.seagate.com/customer/warranty_validation.jsp?form=0
and enter the model-number, and the serial-number, to see if the disk-drive is still under warranty.
If so, Seagate will replace it, at minimal cost to you.
Nov 04, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate external hard drive is flashing blue light
Sounds like you have either bad voltage from your power adapter or a failed enclosure.
First thing to do is check the ac adapter your using, find the output Voltage, should be between 5-16V and the output Amperage, should be between .25A and 5A depending on the type of seagate enclosure you have.
Now look at the stickers on the outside of the drive enclosure to verify that it uses the same voltage and amperage. If it doesn't you're using the wrong adapter(easy mistake after a move). If it's the correct adapter then you may have had a failure in the enclosure.
The next thing to try is to take the drive to your local PC shop and ask the technicians there to transfer the hard drive inside it into a new enclosure for testing. If this works buy the new enclosure and you're on the way. If this also fails, something has failed in the drive itself and you will need the help of a pro. Have the technicians either return it to the original enclosure or pack it in a static free bag.
Now you have a couple options. I can refer you into one of several professional facilities depending on your needs. The most common one I use is www.armor-it.com They are the least expensive on average but average 4-5 weeks for non rush orders. If you need a faster turnaround and don't mind spending a few extra bucks, reply back and including your Country, City and State and I will refer you into an appropriate facility near you.
Crankstart
Jan 06, 2010 | Computers & Internet
After Seagate device not recognized, all flash drives gave troubl
even tho you have AV software installed , I wouldn't write it off so easily. Download and run Malwarebytes from
www.malwarebytes.org
and you may be surprised how ineffective AV software can be some times.
Don't forget to rate the advice!
http://www.aa1consulting.com
Jul 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My Seagate Free Agent Classic external hard drive won't work
Have you tried a different USB port? Some USB chipsets are prone to frying if you use the front accessible ports. Also, try the drive on another computer.
Jan 21, 2009 | Computers & Internet
Seagate problem
YA THAT WILL BE THE NEXT TRY.
TAKE IT OUT AND TRY ANOTHER CASING.
Mar 18, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Seagate freeagent 500g usb 2.0 beeps sound
Mar 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Power indication light flashing
Hi, you may want to try connecting it by USB if you're currently using firewire or the other way around and see if it works. If this fails, you are probably better off using diagnostics by Seagate @ http://www.seagate.com/ww/v/index.jsp?vgnextoid=7f4e19e0babfd010VgnVCM100000dd04090aRCRD&locale=en-US#. Try to use the Troubleshooting or FAQ or if you feel comfortable using their utilities, download SeaTools. Hope this be of help to you. Good luck.
Apr 23, 2007 | Seagate 300GB Pushbutton Backup External...
Seagate Expansion 1 TB USB 2.0 Portable External ST910004EXA101-RK Hard Drive Logo
203 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
