Question about Helman Group HDR-565
Where can I get parts for the fiesta station home buffet server
I have a Tru triple buffet server and am missing the lid rests. I have looked all over and cannot find any replacement parts. Any suggestions?
Good Morning You might want to Contact Select Brands, Might be the manufacturer or your tru buffet server? and ask if the parts are available. Try . www.selectbrands.com. or you can try and call : 913-663-4500 or e-mail at info@selectbrands.com. If you have the model number or serial number they may be able to help. Good Luck.
Sep 18, 2017 | The Kitchen Appliances - Others
Trying to keep large # of hot dogs in buns warm. Do I put water in the roaster before adding the insert containing the hot dogs?
The Owner's Guide for the Rival 18qt Roaster Oven with Buffet Server is available here:
http://www.rivalproducts.com/manuals/MANUALS/RO180BR-C_43_18972586.PDF
See Page 6 for full instructions on use as a buffet server.
You would normally fill the removable roasting pan with 5 to 6 quarts of water ot 1/2 - 3.4 full. Place in the buffet server frame and the empty serving dishes and then preheat at 350 degrees until hot.
Place hot, cooked food in the serving dishes and reduce heat to 250 degree to keep food warm. Adjust the temperature and add more hot water as necessary.
Mar 03, 2011 | Rival 18 Qt Roaster Oven with Buffet...
Elite 18qt Roaster w/Buffet Server can I bake in it to make dressing.
Your Owner's Guide for the Rival 18qt Roaster Oven with Buffet Server can be found here:
See page 6 for instructions on use.
Feb 04, 2011 | Rival 18 Qt Roaster Oven with Buffet...
To use the buffet server, do I need to add water to the liner first?
Yes, to use the buffet server, the folks at Rival recommend 5-6 quarts hot water.
Nov 26, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Do you put water in the botom pan
No water between the roaster and the cooking pan!
If using with the buffet server insert, put a couple inches in tn the cooking pan below the buffet pans.
Here is the manual for additional help:
http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
I want to buy the buffet server for the roaster. My roaster did not come with the buffet server.
Rival akes several 18 quart roasters and not all of them take the buffet server. You can check about yours and order direct on line at the Rival website:
http://www.rivalproducts.com/category.aspx?cid=1117
Nov 22, 2009 | Rival 18 Qt Roaster Oven with Buffet...
How do i use the buffet server. do you put water in the bottom
For the answer to your question, follow this link to the owner's manual. It explains how to use the buffet server among other things.
I hope this helps! :)
Oct 24, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Helman Group HDR-565 Logo
Top Helman Group Kitchen Appliances - Others Experts
Richard Long
Richard Long
Tom Chichester
Are you a Helman Group Kitchen Appliances - Other Expert? Answer questions, earn points and help others
