Question about Hobby King Cyclone-E All Moulded Composite Hotliner 2000mm ARF
Cyclone E fuselage too small
The recommended motor is too big a diameter to fit the fuselage. I have tried to make a new motor mount firewall, but will need to cut the fus shorter. Am I correct to do this? Roy.
Brookstone Helicopter Cloud DSS
In general, the main rotor in an R/C helicopter only tips forward and backwards of vertical center. Direction is determined by the tail rotor. If the entire machine is tilting right, even if the rotor doesn't appear to be, check the motor mount, and or gear train of the main rotor in the fuselage. The main rotor shaft in the fuselage should be exactly vertical relative to the helicopter deck and with trim tabs centered. If your model has the two small fans, one on either side of the fuselage, try replacing the propeller on the right one, even if it looks OK and check for lint or hair on motor shafts. Again, this is a general answer from my own experience. Hope it helps.
Dec 04, 2013 | Electronics - Others
Water leak
Replace that hose. If it's a big hose, it must be one of your two radiator hoses. If it's a small hose (about 1 inch in diameter) it must be one of your two heater hoses, running from the firewall in back of engine to the engine. To replace hoses, drain your radiator before disconnecting hoses, or you will have coolant going everywhere. Good luck.
Jun 16, 2012 | 2004 Pontiac Grand Prix
I can not find a bar to fit the rancher 55. This
The 50/51 and 55 always had the same bar mount, the bar was part no. 508912164 for 15" 508912172 for 18" and 508912180 for the 20", the oil is not fed through the bar adjuster hole.
Aug 18, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Where do u put the water in on a colt? Can't find it?
A tank used for storing excess coolant; connected to the cooling system with a small-diameter overflow hose.
The coolant reservoir is the bottle,under the hood, that holds the radiator fluid. it is also known as a overflow bottle. When the car gets hot,the overflow bottle, releases steam to relive the pressure in the radiator. excess coolant is also stored here.
I hope this helps, Mike from fixya.
Aug 07, 2011 | Mitsubishi Colt Cars & Trucks
Right side cd will not open. Took off cover and if I push down slightly on the apparatus in front of the ribbon the door will open but only if I push down on that point
There is a small round rubber belt which allows a motor to open the tray. Open the tray, as you say you can, Remove the mains plug. Remove the mounting screws for the deck and you will find the small drive belt underneath. I would recommend buying 2 belts and replacing them both. The diameter is 1 or 2 mm less than the old one (because they stretch)
Dec 19, 2010 | Sony RCD-W1 2-Disc CD Recorder
2001 Mitsubishi Galant leaks water into passenger side floor when Air conditioner is on. Whats wrong with the car?
The A/C evaporator drain tube is most likely blocked. If you have a V6, you're in for a real treat trying to reach the thing to clear it. The tube is on the firewall behind the driver's side rear motor mount, and slightly to the left as you're facing the firewall. It is a 1/2" diameter metal tube projecting about 1/2" from the firewall, and is covered by the firewall sound and heat blocking material which has to be folded back to reach the tube. A pair of what I believe are brake lines are one finger's-width in front of it, making it VERY difficult to get to the tube. (Brilliant design, Mitsubishi!) If you are very dexterous, you can slip a small piece of wire or a cable tie under the brake lines and into the tube from the front to try and clear it. Good Luck!
Jul 03, 2010 | 2001 Mitsubishi Galant
May i fit bigger disc on my angle grinder,its speeed is 11000 rnd.p minutes,recomended 115 mm disc.i want to fit other big disc.may i do it?will it cause any problems?
there are 3 problems you might face: 1. mechanical - disc shield (or protector) is too small for bigger disc. You can remove the shield (I do not recommend!!!) or buy bigger one (as I've did). 2. RPMs - on each disc you can find maximal speed of ourter part of the disc. It depends on disc diameter and RPMs. In case yo go from 115 to 125 at 11 000 RPM, it should be still OK. But I would not go further. Check how RPMs drops with increasing disc diameter. 3. motor overload. To handle bigger discs motor should produce higher torque. But if you are not pressing on the grinder and you frequently check temperature of grinder, it should work. I have Metabo WE14-125 - 1400W motor 125 mm disc: 1. I've bought new shield from WE14-150 - it fits perfectly 2. My grinder has adjustable RPMs, when I'm using 150 mm disc I'm not going over level 3 (out of 6) to keep RPM in safe range for the disc. 3. Metabo makes also WE14-150 which is almost same as mine, but produces more torque (3,5Nm vs 3,3Nm). But the dofference is very small so I'm not worried. Juraj
May 01, 2010 | Metabo W14 125 Ergo Angle Grinder 5"
Does the 52mm filters fit a Canon AV1 35mm SLR?
Filters fit lenses, not cameras. Some lenses take large filters, others take small filters. Many lenses have the filter size inscribed on them near the front, followed by something that looks like a Greek phi (a circle with a line through it). Alternatively, since the size is the diameter, you can always measure the lens with a ruler to see how big the diameter of the filter mount is.
Mar 20, 2010 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
I'm trying to recharge the A/C in my 04 PT Cruiser. I can't seem to find an accurate answer to which hose is the low and which is the high side. I have a large diameter hose and a small diameter hose. The...
The low side connectors are diffrent from the high side, you would not be able to connect it anyways. The high side has a bigger port that the low side, and it would not fit anyways.
Aug 04, 2009 | 2006 Chrysler PT Cruiser
Where is the ac drain hose
Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} -- open the driver's door
-- locate where the air conditioner blower box is attached to the passenger side of the firewall – see photo #1 – look to the immediate right at the top of the gas pedal arm
-- condensation flows toward the front of the vehicle through the firewall at the leftmost edge of the air conditioner blower box – drain channel
-- open the hood and stand next to the front wheel on the driver's side
-- look down at the firewall over the battery and to the passenger side of the brake master cylinder – see photo #2
-- locate the small diameter metal tubes running horizontally and attached to the engine compartment firewall
-- locate the hole in the engine compartment firewall panel behind the small diameter metal tubes
-- this hole leads to the drain opening in the air conditioner blower box mounted in the passenger compartment
-- follow the brake tubes as they run from under the vehicle and turn toward the front wheel on the driver's side
-- locate the hole in the engine compartment panel behind the brake tubes
-- insert a short length of stiff wire into the hole through the engine compartment panel to unblock the drain hole
Jul 11, 2009 | 2004 Mitsubishi Endeavor
Hobby King Cyclone-E All Moulded Composite Hotliner 2000mm ARF Logo
Top Hobby King Toys Experts
ray gallant
Are you a Hobby King Toy Expert? Answer questions, earn points and help others
