Question about KitchenAid KSSC42FMS Side by Side Refrigerator
Warm Fridge No Airflow...Control Panel Beeping
Kitchenaid KSSC42FMS01 no cold air is blowing from the freezer into the Fridge. Took it apart and can't find any ice blockage. Top temperature lighted panel is beeping and switching on and off
    Scholar:
  • 61 Answers
I just had the same call today i ordered the damper control because it seems at times more air comes in and than at time like 30 seconds later nothing and the fan is working its not mine fridge but what you can do take the freezer side upper shells off the ice maker on(not necessery but i thought it was easier) and take off the little cover which is covering the damper it has two screws and look inside of the opening and you'll see a damper, turn up the fridge and see if the damper moves and you can turn down the fridge and see if the damper is moving if not you need a damper! good luck
Posted on Jun 06, 2009
Fridge not getting cold
With a top freezer the cold air comes from the freezer down into the fridge. It uses a fan to blow the air down. It's possible that the fan is burned out. Does the fan come on if you turn the temp. to the fridge to colder? If not, then that may be the problem. The fix is not too easy, but can be done by an experienced do-it-yourselfer.
Mar 11, 2012 | Electrolux ER7926B Bottom Freezer...
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
No cold air blowing in fridge but the freezer is working?
The fan that blows cold air out of the freezer into fridge is not working or the passage is blocked check fridge side wall verify openings from freezer are clear and feel for airflow. I need a specific model # to provide better info.
Mar 17, 2010 | KitchenAid Refrigerators
WE have a GE refrigerator-freezer that is cold in the freezer, but is warm in the regrigerator. Model CTS22I Is there anything we can check before calling a repairman?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Dec 29, 2009 | Refrigerators
Kitchenaid Side by Side Refrigerator minus the cold air?
your compressor has issues. some times the start relay goes bad or the compressor windings are shot. thats why it clicks on then off .a service tech can install a "3-n-1 hard start on it. sometimes that works. good luck
Dec 10, 2009 | Washing Machines
Fridge not cold as should be
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 29, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Maytag bottom freezer Model MBF2254HEB not blowing cold air into freezer or fridge, blows warm air if blowing at all, starts and stops. Any suggestions? Possibly a reset button somewhere? Thanks - Kurt
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Refrigerators
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Refrigerator section warm. Freezer section OK.
Most likely it's a defrost system problem. One of the heaters could be bad and that will cause the coils to freeze up reducing the amount of cold air the fan can push into the fridge. Sounds wierd but, trust me, that could be your problem. Mine did that two years ago.
Apr 14, 2009 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid KSSC42FMS Side by Side Refrigerator Logo
645 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
