When i start up my imac monitor wont open
I'm trying to get to the main page hos can i make the monitor to output no input
  • 22 Answers
See if this helps. Appears to be that it can't find a way to boot the OS. Could be a hard drive problem possibly.
https://discussions.apple.com/message/18062260#18062260
Posted on Jan 02, 2014
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
Can a mitsubishi diamond pro 900u connect to imac?
Depends what imac it is.But mostly you just need a adapter to convert the imac's output to the displays output
Apr 24, 2014 | Apple Computers & Internet
Monitoring vocals and cd/tape
Here is a link for the manual, can't download it but you can read it online.THESE words are written on page 9 of the manual," If you are recording a signal via the TAPE OUTPUT and wish to listen to this simultaneously via the CD/TAPE INPUT, do not use the CD/TAPE TO MIX switch. Doing this would create a feedback loop, since the signal would be routed, via the main mix, back to tape via the TAPE OUTPUT. To monitor the CD/TAPE INPUT, use the CD/TAPE TO CTRL switch to assign the tape signal to the monitor(s) or headphones. This will avoid the tape signal being routed to the TAPE OUTPUT."
It also says this under that,"If you want to monitor only the efects signal in your headphones or monitor speaker(s), press the FX TO CTRL switch. Now the signal of the efects processor can be monitored alone, and the main mix andnor CDntape signal is no longer present on the phone and control room outputs."
The link for manual is below
http://www.manualowl.com/swfviewer/viewer.php?ViewModeToolsVisible=true&FitWidthOnLoad=true&Scale=0.6&ZoomToolsVisible=true&ZoomTransition=easeOut&localeChain=en_US&FullScreenAsMaxWindow=true&SwfFile=%2Fmanualswf.php%3Fid%3D333864%26manual_type%3Dproduct%26d%3D2501bc0bd655f7f874a872da268a7ed6&ZoomTime=0.5&NavToolsVisible=true&ProgressiveLoading=true&ZoomInterval=0.1&CursorToolsVisible=true&FitPageOnLoad=false&SearchToolsVisible=true
Feb 28, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    No signal input wen connected to the VGA port of my Dell M1210 (Win 7). using an VGA to DVI cable. If i connect the CG223 to an old laptop (vga) it works fine.
    The Dell M1210 hos only a VGA output or s-video output, both being analog. If you are connecting the M1210 VGA to the DVI input on the monitor then this will not work. You need to connect to the VGA input on the monitor.
    May 25, 2011 | Eizo CG223WBK Monitor
    How to connect 3 LCD monitors to a computer
    Some cards can send 2 outputs that is split by the cable, which is connected to 2 monitors. Generally speaking though, most just split the image up
    If you're not sure if your output supports multiple monitors off one output, it's almost certain it doesn't.
    There is USB 2.0 to DVI, HDMI and VGA Multi-Display Adapter
    resolutions of up to 1600 x 1200 Allows for effortless multitasking
    Jan 05, 2010 | Dell DimensionTM E520 PC Desktop
    My tower wont turn off and monitor says no input signal and keyboard doesnt work
    Do you have two video outputs on your PC ie. one on the motherboard adn a separately installed card maybe? If you do you need to set the BIOS so that it uses the AGP/PCIE video card and not the 'onboard'. Try the onbopard vodeo card first to see if you get a signal there.
    If you do NOT have two video outputs, and you can not see a signal then you may have a prblem wiht your monitor itself. Is this a known working monitor to start with?
    May 12, 2009 | HP Pavilion a1610n PC Desktop
    I have a Sony ICD-SX35 recorder which my iMac will not recognize. Any clues out there???? I need to convert the dvf files into MP3 or WMA format but that can't happen before my Mac recognizes the...
    I took the advice of one of your correspondents by connecting my Sony ICD-SX365 recorder to my iMac with a simple audio cable by inserting the output jack in the recorder's slot for headphones and the input jack in the iMac's slot for microphones. I used the freeware program Audacity to import the track onto the computer and Switch to convert the file to mp3.
    Apr 15, 2009 | Sony ICD-P28 Digital Voice Recorder
    Want to copy files from Tascam 788 to IMAC's Garage Band
    The problem is thus. You have a multitrack recording saved in a format that your portastudio recognizes and you want to use it on your imac. If you can copy the file to the imac as a file, a translator, if one is available, will make it usable by the mac. You won't be able to play it and record on the imac because maintaining the recording as multitrack would require one output from the portastudio and one input on the imac for each recorded track.
    Bummer dude. The kluge method would be to play/record 2 tracks at a time (or however many outputs and inputs are available) and hope for some semblance of time alignment, after which you can fine tune it and then start your editing.
    Apr 09, 2009 | Tascam Electronics - Others
    Computers & Internet Logo
    48 people viewed this question
    David Payne
    David Payne
