Bypassing built in dvd player for another DVD player?
My TruTech 15" TV/DVD player is not working (DVD player)and I would like to bypass it(DVD) to plug in another DVD player.
    Sergeant:
  • 302 Answers
Try using the AVI cord, plug it into AV(1 or 2 etc) and set the TV to that
Posted on Jan 02, 2014
HDTV GURU
  • 261 Answers
SOURCE: DVD player not working
It could be that the DVD player has a bad home switch in the dvd player or that it doesn't know that the door is closed. I have run into similar situations with CD Players years ago. Also keep in mind to unplug unit and let sit for 1 minute to let microprocessor reset. Let me know if that helps. Thank you ...Jay
Posted on Jan 31, 2008
  • 14 Answers
SOURCE: Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Posted on Mar 02, 2008
  • 2318 Answers
SOURCE: My Insignia 26" lcd tv has a built in dvd player that doesn't work.
I would suggest to call the place where you bought it and ask them for an authorized repair center. You TV still under manufacturers warranty.
I could fix it for you. I live in Brampton.
Good Luck.
Posted on Mar 18, 2008
SOURCE: DVD doesnt work
my nephew open the dvd player on my trutech tv now my dvd is broke when i put a dvd disco it does work it make alot of noices . what should i do to fix the dvd player i buy about year ago i done have warranty on the tv help want can i do
Posted on Sep 21, 2008
  • 8 Answers
SOURCE: dvd stuck in the dvd / tv
I had this same problem and fixed it too. It was from a flat torsion spring on the loading mechanism that had moved position. It hits against the chassis of the DVD housing preventing the mechanism from seating the disk on the spindle. Result is a stuck disk and/or constantly running loading motor.
Remove the one black machine screw behind the DVD player. DVD player will slide out of TV with its black plastic trim fascia from bay.
Remove two screws that hold fascia panel, remove fascia and lift off top metal cover.
With CD loading slot facing you, the problem spring (in our situation) was at the left. Also identical spring on the right side too. These are the two torsion springs near the front on sides of chassis. The helical loop on the left should be towards the top. If it shifted to the bottom, it can hit the tab with screw used to secure DVD chassis. When this happens, CD loading mech can't complete loading disk onto the spindle. If spring flips when the CD is on the spindle.... disk can't eject.
I used a pair of tweezers to gently grab the spring and "flip" it upwards by pulling it upwards. Spring will work for mechanism in up or down position, but needs to be up to avoid interence.
Solved my problem and DVD has been great since. If it flips back for some reason, then I will try attaching a small piece of plastic to the side of the chassis to contain spring in upright position only.
Posted on Feb 24, 2009
Bypassing built-in TV/DVD Player for another DVD player
Connect another DVD player to an unused input port on the back of the tv. If there is a HDMI port available connect it there if the dvd player has HDMI. Then all you have to do is change the input number on the tv. If you get picture but no sound, use RCA audio cables from the player to the tv. Not all HDMI cables pass audio.
Jan 02, 2014 | Televison & Video
TruTech tv with built in DVD player not playing DVD's
the possible of dvd, its lince, its possible damage, specialy when use dvd has scrahts. try to clean useing cotton bads only, clean smothly, then try to use,
Apr 17, 2010 | TruTech PLV16190 Television
Hook up new dvd player
you need to tell the t.v. via the remote which input it is supposed to be looking at in the uk the button to press is usually called av, press this and it will go av1 av2,etc look on the back of t.v. to see which one you are plugged into and this should cure it please leave feedback thanks
Jul 20, 2009 | TruTech PM1919BXA1 19 in. LCD TV
My DVD player on my TV is broken
I think you should make your kids pay for the broken DVD player in your TV
Feb 07, 2009 | TruTech PVS31170S1W 17 in. LCD Television
TV won't playback DVD-RW Disc recorded on another TV.
THE PLAYER IN THIS MODEL DOES NOT READ DVD+ OR DVD- OR DVD RW DISKS ITS NOT GOING TO HAPPEN! CHEAP PLAYER INSIDE WILL ONLY PLAY STORE BOUGHT DVDS
Nov 23, 2008 | TruTech PLV16320 Television
My dvd player does work on my tv
your dvd mechanism or the entire dvd compartmet has to be change
Sep 21, 2008 | TruTech PLV16260 Television
Jan 19, 2008 | TruTech PVS2119 19 in. LCD Television
DVD doesnt work
Replace the laser on DVD player and that will resolve your problem. Todays lasers are not that reliable
Nov 29, 2007 | TruTech PLV16260 Television
Trutech 17 " lcd tv and dvd
Customer Support for that TV is at http://www.1800customersupport.com/trutech. Check the website and email or call their customer service department for help.
Aug 21, 2007 | TruTech PLV1615T 15 in. LCD Television
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
