Question about Onkyo TX-SR604 Receiver
Automatic speaker set up tx-sr604
I am at step 1 and running the measuring test.  I do not have surround sound speakers and I only have the "back" surround speakers.  I get "no" on left and right on the surrounds and "yes on everything else except the "yes" for the backs are blinking and I am getter an "error detect" message.  I have retried several times including shutting machine off and it won't send me the the "next" page.
  • Anonymous Dec 25, 2007
    Exact same problem here. I am using front/main speakers, a center channel, and rear but no side or sub.
Take all the red and twist together and same with blake and put thim in the A speekers no serowund just stario
Posted on Jan 06, 2008
A and b wont come on at all only surround sound
Verify the main speakers are not blown or cables damaged or disconnected. If you have an ohmmeter, set it to ohms and measure across the speakers with no cables connected. You should see 3-9 ohms. Anything higher will indicate problems in the speaker(S). Get them reconed or replace defective speakers.
If the speakers test ok, remove the cables from the amp and speakers. Test your speaker cables by shorting both wires together on one end of the first cable. Connect the ohmmeter, set to ohms, to each wire on the opposite end. You should see near 0 or maybe 1 ohm. If not, the cable is open. Do the same with the other cable.
If these tests all pass, you have a more serious problem in the amp. You will have to take it to a reputable shop. Good luck!
Apr 22, 2014 | Pioneer VSX-D411 Receiver
I have had my Marantz Sr5000 for some time now and I just noticed the rear speakers have stopped working. Everything else seems to be working fine. When I run the test tone I get a tone from everything but...
First of all if you have not made any connection changes in the system prior to loosing the sound try these steps.
Go into the system menu and in speaker configuration see if somebody has given the rear ( surround ) speakers as none. If not just exchange the front and back speakers to confirm if its a speaker failure . If not you will need professional help to fix a damaged surround amplifier.
Mar 08, 2011 | Marantz SR-5000
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Yamaha HTR-6030: all speaker have sound coming out but it is not true surround. The display only shows front speakers on, how do I get all speakers to come up on the display?
I think you mean the display only shows Front >>Channels<< available.
What source? Digital or analog (analog is only stereo).
Dec 27, 2009 | Yamaha HTR-6030 Receiver
Surround speakers are not working
Yes. Make sure your speakers are first properly connected, then enabled to operate on the setup menu. Then run either a test tone for all channels or media recorded in surround sound or run in 4 channel stereo to test.
Not all media will produce surround effects 100% of the time.
Jun 18, 2009 | Denon AVR-3300 Receiver
What to do
Hello dodgeram1980,
If you are not getting sound from any of the 4 channels, I'd suspect that either the amp is not getting an input signal or the amp itself is faulty.
Here's the "no sound" troubleshooting step-by-step procedure from the JL manual:
1) Check the input signal using an AC voltmeter to measure the
voltage from the source unit while an appropriate test tone is
played through the source unit (disconnect the input cables
from the amplifier prior to this test). The frequency used should be in the range that is to be amplified by the amplifier (example; 50 Hz for a sub bass application or 1 kHz for a full range / high-pass application). A steady, sufficient voltage (between 200mV and 5.O-volts) should be present at the output of the signal cables.
2) Check the output of the amplifier. Using the procedure explained
in the previous check item (after plugging the input cables back into the amplifier) test for output at the speaker outputs of the amplifier. Unless you enjoy test tones at high levels, it is a good idea to remove the Speaker Connector Plugs from the amplifier while doing this. Turn the volume up approximately half way. 5V or more should be measured at the speaker outputs. This output level can vary greatly between amplifiers but it should not be in the millivolt range with the source unit at half volume. If you are reading
sufficient voltage, check your speaker connections as explained below.
3) Check to ensure that the speaker wires are making a good
connection with the metal inside the Speaker Connector Plugs. The speaker wire connectors are designed to accept up to 12 AWG wire. Make sure to strip the wire to allow for a sufficient connection with the metal inside each terminal.
Hope this helps.
Apr 30, 2009 | Jl Audio HD600/4 Car Amp
No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Apr 14, 2009 | Yamaha HTR-5730 Receiver
No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Itunes assigned to CD stereo outputs to zone 1 but not zone 2
Ron Digital audio will only reproduce in the surround area you will have to connect using analog connections in order to get that sound in the 2nd zone
Dec 14, 2008 | Denon AVR-2807 Receiver
Rear speaker connection issue
OK, the fix for the missing rear speaker sound on the DELL WL6000 5.1 Surround Speaker System is relatively simple, just 7 simple steps (Verified by Dell at http://support2.jp.dell.com/docs/acc/P121646/multlang/srg/DAO/srg_dao.pdf..
First, power down everything. Second, disconnect the rear speaker and subwoofer from the power source and wait about 5 minutes. Third, be sure the power switch is off on subwoofer and the center speaker. Fourth, plug in the power for the subwoofer but DO NOT turn on the power yet. Fifth, plug in the rear speaker power cord. Sixth, turn on the swtich on the subwoofer (this is the start of the resync mode). Seventh, turn on the center speaker power and the system will change the rear speaker system LED from flashing blue to solid blue in 5-8 seconds. The surround system is functioning again. You may test this under sound in the Control Panel but I would prefer to use a modern music CD that has Dolby Digital Support for 5.1 sound or better. YOU WILL HEAR INSTANTLY THE SOUND DIFFERENCE WHEN THE REAR SPEAKERS ARE CONNECTED.
Nov 10, 2007 | Dell WL6000 Computer Speakers
Onkyo TX-SR604 Receiver Logo
94 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
