Question about Grilling
Uniflame gtc1205whl I'm not sure if we are missing a part or whatnot but the standard 1lb propane does not connect to the grill burners. The piece from the regulator to the gas chamber in the grill is not sealed. Am I doing this wrong or how can I find the part I need?
  • 4 Answers
Read the owner's manual to find all the pieces. I'm sure you're missing a part
Posted on Jan 02, 2014
4 Suggested Answers
  • 57 Answers
SOURCE: Center part of burner on Uniflame Gas Grill is
yes you can each burner has a air vent close that air vent a little bit or till it has a blue flame
Posted on Aug 23, 2009
  • 57 Answers
SOURCE: I have a Uniflame Model
it is the regulator go to home depot and buy one
Posted on Aug 25, 2009
hunter19_46m
  • 7482 Answers
SOURCE: have a type 6980 gas regulator not getting enough gas to the burner
Hi leonard4538
Regulators are notorious for doing just what yours is doing.
After sitting in the same position for a length of time they freeze in that position, then along comes a grain of sand, or other debris and blocks the gas flow.
Remove the regulator if possible, if not try it in place with the tank removed.
Get a plastic headed hammer and gently but firmly tap on the regulator, your trying to free up the diaghram inside.
After tapping and freeing the regulator diaphram reinstall and you will be good to go.
If this does not work, the replace the regulator as it is defective.
Some regulators are ajustable, if you have one of those then try to adjust the regulator, you will see a cap on top of the regulator, that is where the adjustment screw is located.
Please take time to rate me
Bud
Posted on Oct 27, 2012
I am looking for replacement burners (4) for a uniflame grill model gbc772w-c. The original ones were brass.
You don't see brass burners much any more, because of the iron content. However, stainless steel replacement burners are available for your model. Check them out at the link below.
http://www.clagrills.com/grillparts/uniflame/uniflame-grill-parts-home.htm
I hope this helps you and Happy Grilling!!
Jul 19, 2011 | Grilling
I have a uniflame grill that the flames barely trickle out,
clean the burner in clr check orffice is not blocked try this and see if flame is better
May 17, 2010 | Uniflame FG2204C Grill
Why wont my burners light up with a new propane gas tank
Some grills have a safety gas shut off if a leak is detected. Suggest you turn gas off disconnect connections then reconnect and check connections with soapy water. When turning gas tank on open valve very slow.
May 12, 2010 | Uniflame FG2204C Grill
Center part of burner on Uniflame Gas Grill is burning too high. How can I adjust this? The burner is one piece and the grill has 3 control knobs.
Aug 13, 2009 | Grilling
Uniflame gbc820w propane to natural gas adapter question
Most major hardware stores that sell grills have a universal conversion quick connect hose and gas line adapter fitting.  That.. you can probably handle.   Next you need to install a quick connect adapter from the house gas line or meter (unless one is already there for you).  Otherwise you may want to call your local gas company or fireplace/grill store to send someone out.    Last all LP to NG conversions require the orifices on the back of your grill's valves to be changed to larger holes.  (LP has more pressure thus small holes and NG must be larger.)  The trick is getting the precise numbered drill bit diameter(45-55) for your particular grill.  You can look on your manufacturers web site to provide this info.  Often times they can sell you a new set of orifices, predrilled, to the exact diameter for conversion.  Drilling out orifices is usually cheaper and pretty easy if you know where to find the bits (internet or specialty tool store).   Sometimes your local gas company or fireplace/grill shop will provide this service as well. Hope this helps, and good luck.
Mar 28, 2009 | Grilling
My Uniflame middle burner wont work cuz I turned knob to far.
it the value u need a new one call Atlanta Grill Service they can get it for you 770-667-5342
Mar 25, 2009 | Uniflame FG2204C Grill
Lack of heat
The plates protect the burners and help disperse the flame more evenly across the grill surface. Make sure the tank is completely open (knob on top of tank) and that when the burner is turned up to high, the flames out of the burners are about 1 1/2 to 2" long, mostly blue in color. If they are smaller, and the tank is open all the way, the regulator hose may be defective.
Jun 19, 2008 | Uniflame 200209 Open Flame Patio Heater
Grilling Logo
46 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
