Question about Pitco Frialator Kitchen Appliances - Others
Fryerlator Mod: WG14S3WF will not come on. Have power to unit Have no wirreing diag suspect control transformer PP10210. Have new transformer but no instructions as to coil connections.
  • ronaldv498 May 20, 2009
    The new transformer has a complete different lug configuration. There usually is some indication of pri to sec etc but in this case the new lugs are just numbered. 1 2 3 5 6 8 10.
  • 3,230 Answers
First of all i want to tell you that there are many diffrent coil connection settings for diffrent appliances...
The only way is that -
1. you can see the old transformer settings.
2. Check tham using a voltmeter.
Post bak for motre assistance.
Regards
all-guru
Posted on May 20, 2009
  • Mukesh Kumar May 20, 2009
    Ok...
    This transformar is diffrent from the old one...
    There is now way from here to find the perfect wires....
    May be it some damage to unit.
Indoor unit working ,outdoor unit fan and compressor won't start
Tell me more. But first "suspect" is a bad power relay. But are you sure the breaker has not "popped"? 2. 24vac transformer for thermostat signals is out. Does it have power? Could be on the same circuit as the outside unit (condensing unit), or another one that may have "Popped" First one will be a 220vac breaker, the second one will be standard 110vac. If you find a "popped" breaker and it pops again when you try to reset it, you need to call an electrician. Or HVAC technician. Be prepared for the worst.
Mar 12, 2015 | Heating & Cooling
Our mastercool thermostat does not have any power going to it whatsoever. It is only a 3 year old unit and we have checked all the fuses and wiring which all seem to be fine. We even changed the main...
If it's a 24 volt thermostat, the inline transformer has failed and needs to be replaced. Some are 18 volts, and they require a transformer too. I suspect that's the problem, since the T-Stat is not getting power.
Hope this helps you solve the problem. Please let me know. Thanks.
May 06, 2011 | Mastercool 67680 Evaporative Cooler Air...
Have had major snow storms in the past few weeks. Installed, prior to storms, new door chimes that worked. Since the storms, neither the front nor side bells function. The bell button has a light on...
Most times, doorbell problems are button, especially since indicator light shows you have power.
Take off front doorbell button and see two wires.
These wires are low voltage and safe to touch.
Use screwdriver and touch both screws together, or remove wires from button and then touch two wires together.
If doorbell rings, then replace button.
If bell still doesn't work then scratch two wires together and look for static-type spark that says wires have power.
If wires have power, and you crossed both wires and bell didn't work, then new door chime is suspect.
If wires do not have power, then transformer is suspect.
Open following link to see example transformer:
http://waterheatertimer.org/images/attic-transformer10.jpg
Transformers are located in basement or attic.
Scratch a wire across both screws on transformer and look for static-like spark.
If no power, then check circuit breaker.
Home centers sell transformers in the doorbell section. They are 12 and 24 volt. Check markings on old transformer.
If transformer has power, then new door chime is suspect.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | Garden
EHT Faliure and kindly give me the alternate EHT details .
Hi Rayjanardank
Eht on all modern ctv is generated with in the flyback transformer , although some older tv set use a triplier unit feed with a 8kv pulse from the flyback transforme
To find out the one that you have got , if the flyback transformer as two controls A1 and Focus mounted on it then the eht is generated inside, if the Focus contol is mounted on the tippler unit unit .As you do not state the make mod No of tv i cannot be of any more assistant but you could cheek the A1 voltage on the crt base , if this is about 350/430volt then the eht should be ok. Hope this might help with your problem.
Regards windyhouse.
m.
Dec 03, 2010 | Televison & Video
GE PROFILE PTS22LHPARWW ICEMAKER NOT WORKINNG
change or remove filter
change control valve
change valve on copper water ine
change copper water line
check input pressure to unit
25? 25? anybody know what is the minimum water pressure supposed to be entering the refrigerator icemaker?
Oct 23, 2009 | GE Refrigerators
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Unit won't power up completely
The clicks you hear are the relay that completes the circuit for 110V AC to the main power transformer. Mine had the same problem and here's how I've gotten it to work. A lightning strike near our house caused it to fail, and I traced it to the power transformer relay activation circuit. The tuner and amp were fine. I found a bad transistor in the relay circuit, but didn't have a replacement on hand, so I soldered a jumper wire across the relay switch connections on the power transformer circuit board. This connects the 110V AC directly to the power transformer. DC Power to the amp and tuner circuits will still be controlled by the power switch, but the transformer will be supplying all the AC voltages to the main board. If there is a real problem with the circuits that load the transformer or the transformer itself, then the fuse will blow. If the fuse doesn't blow then I suspect the problem is just in the power sequencing circuit itself, that is not needed for operation other than to make the unit "Energy Star Compliant". A lot of electronic items have a transformer that is not switched, and only fused, so that the supplies are available at all times.
Jan 24, 2008 | Audio Players & Recorders
Microwave
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Jan 02, 2008 | Microwave Ovens
Kitchen Appliances - Others Logo
46 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
starztruck4u
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
