Question about Toshiba Sm-352 Cd-rw/dvd Drive
How do i hook it up to a new computer with sata drives
Just wondering if it can be hooked up
    Sergeant:
  • 279 Answers
If you have a Parallel-ATA port on your motherboard like the port pictured here...
how do i hook it up to a new computer with sata dr - 1_5_2014_4_04_51_pm.jpg
...then you should have no problem using that drive in your new PC.
Posted on Jan 05, 2014
I hook up the sata bridge adaptor and my computer is not reconizing the the hard drive is even there i can hook it up to ide and it works fine just wont work with the bridge
The bridge has a jumper I believe next to where the powerplug is. This jumper must be pulled out and put on the A-B NOT the A-C if youare going to use the IDE ribbon cable. Another trick is do not use the IDEcable (extra) that you may have with or below or above your other harddrivesince bios will always keep trying to go to your SATA drive even when youchange your primary drive with working operating system to slave and changeboot order....will just show on screen something like no boot disc. The easiestway without messing with the bios and drivers and all is this....move jumper toA-C then use one of the IDE cables that you have (you should have 2) of youCD-ROM. If you are using 2 CD-ROM's remove one and plug this IDE cable intoyour SATA bridge. The computer will now find new hardware. Then right clickthat new found drive when you click "My Computer" from"Start" and "Format" it, just to make sure everything is off thedrive even if new it will not hurt. Not sure if you want your SATA to be yourprimary drive but if you do,you now can use Acronis Ghost software or other tomirror your primary drive onto your new SATA. Once done take out or dissconnectyour primary drive and install your SATA into that slot or above or below yourprimary drive if you have available room in your tower then hook that IDE cableto your SATA and hook power. BAM.. your computer will now use the SATA to bootup and all is fine. Remember SATA does not have slave/master jumpers like IDEdrives. Now if anything happens to that SATA you still have you disconnectedprimary drive to fall back on. If your concerned about wanting 2 drives you maybe able to take your original primary drive and change that jumper from Masterto Slave.Since bios will default to your new SATA drive now and use that hasyour master and boot up from that drive. If you do not want to use yourSATA as your primary without installing an operating system or usingghost/mirror software then to make life easier just use the IDE cable from oneof the CD-ROM's or get an extension IDE cable that will reach since your SATAdrive is smaller and most likely will not neatly fit into the CD-ROM slots. Youcan use the extra slot if you have one above or below your primary drive yourusing now, then plug your CD-ROM IDE cable (with extension if needed to reach)into SATA and then you can now use the SATA to send files and anything else youwant to store in that drive. Hope this helps.
Dec 29, 2010 | Kingwin SATA to IDE Bridge Board (ADP06)...
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
Can't see SATA drive
HI,
Let me first make sure I understand what configuration you have here. You've installed a new SATA drive and installed Vista on that SATA drive on this new motherboard. Then your trying to add an additional SATA drive to the motherboard that has data on it, but no OS. Is this correct? The problem your having is that when you put the drive with the new installation of vista on it, along with the old drive both being SATA, the old drive doesn't appear in vista but it does in Bios?:
Ok, if I'm correct in your config here, I would hook the new drive to SATA 1 and the older drive to SATA 2, and in bios boot to SATA 1. When you boot to vista, go my computer and right click to manage. Under manage go to disk management. It should see both drives and their you can format the second drive. If it doesn't see it, then try another SATA port.
Let me know, since I'm not confident on my assumptions.
Thanks
Mark
Mar 10, 2010 | EliteGroup ECS A780GM-A Motherboard - AMD...
Hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
Sep 15, 2009 | Lite On LITEON 8X DVDRW +/- Burner
I have a Plumax enclosure I am trying to use. When I hook up my WD800 ide drive nothing seems to work. The power comes on, and the HDrive spins but my vista 64 desktop does not recognize or show the drive...
Try hooking it up to a different USB port. Go to computer on the start menu and see if your computer sees it. Try restarting your computer with the hard drive already connected and turned on, the computer may recognize it then.
Aug 23, 2009 | Plumax PM-350SI-PJS SIlver 3.5" Combo...
Need diagram of how to hook up my western digitial sata harddrive to mother board a asus a7n8x-e deluxe
this motherboard does not support your new Hard Drive. SATA is a connection type required for your hard drive. Your motherboard supports IDE connector. You probably can get a pci card that allows you to attach the hard drive.
May 24, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
Hard drive switching (dead one to new one)
Your computer comes with an Sata hard drive. I am guessing that you have purchased a IDE one. If sio , return the IDE drive in exchange for an Sata one. He is the manufactures web site for your machine:
http://support.dell.com/support/edocs/systems/dim8400/en/index.htm#printed_documentation
Dec 09, 2008 | Dell Dimension 8400 PC Desktop
Toshiba Sm-352 Cd-rw/dvd Drive Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
