Question about American Standard 2175.502.002 Colony Soft Single-Control Lavatory Faucet w
Mine leaks handle and cap (housing cartridge)
My american standard faucet leaks from where the handle meets the cap that covers the cartridge. How do I disassemble the handle to see what is wrong and to replace parts if possible? What kind of screws do I need? and where to look? Thanks.
    Problem Solver:
  • 13 Answers
There should be a little cap covering a allen srew in the front or back of the handle it sometimes looks like the hot or cold sign or chrome pop that off and loosen the screw and pull off the handle there should be a nut loosen that and pull up the cartridge you might be able to find one at home depot be sure to turn the water supply off
Posted on May 27, 2009
When dishwasher is running, water leaks under base of our American Standard Colony model soft two-handle kitchen faucet into cabinet beneath sink
Is there an air gap next to the faucet that is leaking. If so, it is probably clogged. Pull the cap off of it and clean it out. This is what it may look like before you take the cap off.
b7ookdehz3uf293omx2ye0fveemyn-clsycdlpsjpi2zdtnzgmj_hhepw5uyprhfsmyzy7tnfmt6uzrk1edu-duydxm839afzrsaplofdfdjymmjvj8xncabtrcoevtu5jguw1elsvyttyypguy-89xi_btsfhkvzgvdbfbda26sii9hwd8sgq
Jan 16, 2011 | American Standard 4275.550.002 ColonySoft...
I have an american standard kitchen faucet, when the handle is half open I get a leak, at home depot where I bought it two years ago, they told me I need to take it apart to see which kit will repair...
The single handled faucets have a valve cartridge which needs to be replaced when it leaks. Disassemble the handle to find the valve inside. Take the valve to the hardware store to be sure you get the right one and reassemble. To disassemble, pop the cap off the lever, unscrew the single screw, then use slip-joint pliers to loosen the retainer nut. lift the cartridge out with pliers taking note of the direction of the notch at the top of the stem. Be sure to reassemble with the notch facing in the same direction. You should replace and lubricate the O-rings when you change the valve cartridge.
Since you have the numbers for that particular faucet, you might want to call around to find the cartridge first. Different models have different valves, so be sure yours is correct.
Oct 08, 2010 | American Standard Kitchen Faucet 6310 020...
I have an american standard bathroom faucet. Single handle. It is leaking where the faucet meets the sink. I do not see any screws to take off the handle. How do I fix it?
First, turn off the water supply under the sink. Next, put the faucet lever in the up position, no water should be coming out. While in the up position turn slowly while looking at the underside of the handle and you should be able to find a set screw. It will probable be an "allen head" type and you will need and allen head wrench to loosen it. An allen head looks like a hex shape, 6 sided I believe and is rod shaped. If you don't have one they come in sets at your local hardeware.
Jul 16, 2010 | American Standard - Lavatory Faucet -...
American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Jul 15, 2009 | American Standard Kitchen Faucet 6310 020...
How to replace sprout seal kit?
After you remove the handle, the chrome cap should either snap or spin off.It also may come out with the cartridge... There are 3 screws that hold the cartidge in the faucet...take them out and you should be able carefully work the faucet are off of the core of the faucet. Put a little cooking oil on the o-rings after you install the new ones... just to allow the faucet arm to slide on without damage... Hope this gets you dripless!! Let me know if you have a question. K
Jun 05, 2009 | American Standard 4175.200.002 Colony...
How to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Leak in the faucet handle
Here is a link to the manual,Page 2 and 3 has the info you need.
Please take time to rate this a fixya
May 20, 2009 | American Standard 4175.200.002 Colony...
How do you change the cartrige for easy touch american standart k
unscrew a alen screw on the underside of the handle.
unscrew the cap that is holding the main body of the fixture.
pull up the fixture.
install in reverse order.
Jan 06, 2009 | American Standard Kitchen Faucet 6310 020...
American Standard 2175.502.002 Colony Soft Single-Control Lavatory Faucet w Logo
198 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
