Question about Lavazza Espresso Point Capsule Machine
What amps are the fuses - Lavazza Espresso Point Capsule Machine
Does all the fuses in a 1987 Ford pickup have to be the exact amperage that is called for in the owners manual?
No they do not have to be the same, However I would suggest not using a lower Amp fuse Example I would not replace a 15 amp fuse with a 10 amp fuse however it is ok to use a bit higher fuse like a 20 amp fuse instead of a 15 amp fuse, I hope this helps.
Nov 26, 2016 | Ford Cars & Trucks
Which fuse do I need to change for electric seats and door locks in my 2003 mercury mountaineer
i have bad news for you the seats and door looks do not chair a common fuse.
power door locks, 4 fues in this system
in the under hood fuse box fuse # 16 15amp, fuse # 2 30 amp, fuse # 22 20 amp
in side fuse box behing left side of the dash fuse # 20 5 amp.
power seats
in side fuse box behind left side of dash fuse #1 30 amp, fuse # 2 30 amp.
Jul 29, 2011 | Mercury Mountaineer Cars & Trucks
Need 1959 corvette fuse box diagram, what size fuse goes where ?
LIGHT SWITCH 15 AMP FUSE CIRCUIT BREAKER / TAIL , DOME , COURTESY 10 AMP FUSE / MANUAL RADIO 4 AMP FUSE / AUTOMATIC RADIO 7.5 AMP FUSE / HEATER 10 AMP FUSE / AIR-CONDITIONER 20 AMP FUSE / BACK UP AND BRAKE ON 10 AMP FUSE / POWER ANTENNA 15 AMP FUSE. THE ELECTRICAL BOOK DIDNT HAVE A DIAGRAM BUT IT TOLD WHAT AMP EACH COMPONENT USES AND VOLTS FROM GENERATOR. IF YOU HAVE A 55 CORVETTE YOU HAVE 6 VOLT ELECTRICAL SYSTEM.IF THIS DONT HELP YOU CAN GO ON LINE AND BUY A 59 CORVETTE REPAIR MANUAL.
Aug 09, 2010 | Chevrolet Corvette Cars & Trucks
What fuse is for the clock in my 95 ford taurus
Clock Memory Fuse 8 and Digital Clock Fuse 6 .
A/C Compressor Clutch Fuse 17
A/C Heater Control Switch Fuse 17
A/C-Heater Mode Switch Fuse 9
Air Bag Diagnostic Monitor Fuse 7
Air Bags Fuse 5
Amplifier Fuse 11
Autolamp Dual Coil Relay Fuse 4
Backup Lamps Fuse 5
Blower Motor Speed Controller Fuse 17
Clock Memory Fuse 8
Courtesy Lamps Fuses 6 & 8
Daytime Running Lamps Fuses 5 & 10
Digital Instrument Cluster Fuses 5 & 16
EATC Blend Door Actuator [1] Fuse 17
EATC Blower Motor [1] Fuse 9
EATC Control Module [1] Fuses 5 & 16
Exterior Lamps Fuses 4 & 15
Flash-to-Pass Switch Fuse 10
Hazard Lamps Fuse 1
Heated Oxygen Sensor Fuse 5
Illuminated Entry Fuse 5
Illuminated Entry Module Fuse 8
Instrument Illumination Fuse 13
Keyless Entry Fuses 5 & 8
LCD Dimming Relay Fuse 6
Lamps On Warning Fuse 4
Lamp Out Warning Fuses 6 & 15
Liftgate Window Defrost Fuse 6
Liftgate Window Washer Fuse 6
Liftgate Window Wiper Fuse 6
Light Sensor/Amplifier Fuse 18
Low Oil Level Relay Fuse 18
Main Light Switch Fuse 6
Manual Lever Position Sensor Fuses 5 & 10
Mobile Telephone Transceiver Fuse 11
Police Accessory Relay Fuse 6
Power Antenna Fuse 11
Power Mirrors Fuse 8
Power Windows Fuse 6
Radio Fuse 11
Radio Memory Fuse 8
Rear Window Defrost Fuse 5
Redundant Radio Control Fuse 11
Shift Lock Actuator Fuse 5
Speed Control Amplifier Fuse 6
Speed Control Deactivator Switch Fuse 1
Stop Lamps Fuse 1
Transmission Control Switch Fuse 18
Turn Lamps Fuse 1
Turn Signals Fuse 5
Variable Assist Power Steering Module Fuse 5
Warning Chime Fuse 6
Warning Chime Module Fuse 18
Warning Indicators Fuse 18
Windshield Wiper Control Module Fuse 2
Windshield Wiper Motor Fuse 2.
this will help.thanks.
Feb 20, 2010 | 1995 Ford Taurus
Which fuse is used for the ecu on a 2002 nissan sentra?
There are three fuses. If your vehicle is equipped with the QG18DE fuse 17 (10 amp fuse ) is located under the dash in the fuse box. And fuse 34 ( 15 amp fuse ) and fuse 36 ( 10 amp fuse ) are located under the hood.
If your vehicle is equipped with the QR25DE fuse 17 (40 amp fusible link ), 34 and 36 ( both are 15 amp fuses )are all located under the hood in the fuse box
Dec 05, 2009 | 2002 Nissan Sentra
Need fuse box pannel to see what fuse is what
FUSE USAGE
1. 10 AMP LOW BEAM-LEFT
2. 10 AMP LOW BEAM-RIGHT
3. 30 AMP BRKR POWER WDO/SUNROOF
4. 30 AMP BRKR PWR ACSRY
5. 20 AMP BRKR LIGHNG CONTROL MODULE
6. 15 AMP IGN/REM ACSRY CONT/INST CSTR
7. 10 AMP SUPPLEMENTAL INFLATABLE RST
8. 20 AMP CORNERING LPS/TURN SIG
9. 10 AMP CRANK SIGNAL-SIR
10. 20 AMP TRK REL/FUEL FILL REL/BACK-UP LPS
11. 15 AMP BAT/RADIO/PWR ANT/CIG LGTR/ INST CSTR
12. 20 AMP ELECTRONIC LEVEL CONTROL
13. 20 AMP BRAKE & HAZARD LAMPS
14. 15 AMP PARK LAMPS
15. 15 AMP COURTESY LPS/PWR MIRRORS
16. 10 AMP COOLING FAN
17. 25 AMP HEATING/AIR CONDITIONING (C67)
18. 15 AMP A/C AUTOMATIC ELECTRONIC (CJ2)
19. 10 AMP ANTILOCK BRAKES
20. 10 AMP LOW COOLANT/LAMP MONITOR
21. 10 AMP IP LIGHTS
22. 10 AMP HI BEAM-RIGHT
23. 10 AMP HI BEAM-LEFT
24 10 AMP IGNITION/RADIO
25 25 AMP WIPER/WASHER
FOR ACCESS TO ADDITIONAL FUSES
REMOVE RIHT SOUND INSULATOR
May 16, 2009 | 1991 Buick Park Avenue
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
I need a fuse box diagram for a 1992 Ford Ranger. Any idea where I could find one?
owner manual.
here's the big ones for 1994 ranger. all i have
Section 18-01: Wiring and Circuit Protection 1994 All Ranger, Explorer and Aerostar Vehicles Workshop Manual
SPECIFICATIONS Specifications
High Current Fuses And Circuit Breaker — Ranger 2.3L, 3.0L And 4.0L
Circuit Size Location Electric Fuel Pump 20 Amp Fuse Power Distribution Box Headlamp Switch Feed 40 Amp High
Current Fuse Power Distribution Box #36 Circuit Alternator Output #2 15 Amp Fuse Power Distribution Box Fuse Panel 60 Amp High
Current Fuse Power Distribution Box Power Locks 20 Amp High
Current Fuse Power Distribution Box #38 Circuit Alternator Output #1 12 Ga Fusible
Link Integral with 14305 W/A Powertrain Control Module and Power Relay 30 Amp High
Current Fuse Power Distribution Box 4x4 Electric Shift 20 Amp High
Current Fuse Power Distribution Box Ignition Switch Feed 60 Amp High
Current Fuse Power Distribution Box High Beams and High Beam Indicator 22 Amp C.B. Integral with Headlamp Switch Front Wiper and Washer 6 Amp C.B. In Fuse Panel Power Windows 30 Amp C.B. In Fuse Panel Cigarette Lighter, Flash to Pass and Power Lumbar 20 Amp C.B. In Fuse Panel
May 13, 2009 | 1992 Ford Ranger
Blowing of fuses
The reason your blowing fuses is the amp needs at the least a 150 amp fuse on the wire that runs to your bat. There are fuse blocks that you can put 4 40amp fuse and theres the high dollor ones that you can put all the way to 200amp. When you trun up your amp its drawing to much current for the little 40 amp fuse that you have and will blow it everytime. I recomend Running a 4 gage wire to bat and ground with same. Get you a 150 or above amp fuse from a car audio shop somewhere. anyway sounds like from what you decribed, theres nothing wrong with your amp just the wires and fuse are not big enouf to handle the current that your amp pulls.
Oct 21, 2008 | Lanzar OPTI 50c Car Audio Amplifier
Fuse
try a 60 amp fuses if it doesnt blow when you crank it up it safer lest chance to frying something 100 amp is lots of juice
Jan 17, 2008 | Alpine MRP-M650 Car Audio Amplifier
Lavazza Espresso Point Capsule Machine Logo
16 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
