Have a 'ticking sound" in the rigt side of y head, with a mil headache- should I be concerned. any advice?Than you
Was wondering if it is from sdtress?
  • 451 Answers
Http://www.webmd.com/oral-health/guide/temporomandibular-disorders
You may have TMD. Check out this website for more information. Hope this helps.
Posted on Jan 02, 2014
Cluster headaches
Cluster headache (CH) is a neurological disorder characterized by recurrent, severe headaches on one side of the head, typically around the eye.[1] There are often accompanying autonomic symptoms during the headache such as eye watering, nasal congestion and swelling of and around the eye, all confined to the side of the head with the pain.[1]
Cluster headache belongs to a group of primary headache disorders, classified as trigeminal autonomic cephalalgias or (TACs). The condition is named for the demonstrated grouping of headache attacks occurring together (cluster).[1] Individuals typically experience repeated attacks of excruciatingly severe unilateral headache pain.[2] CH attacks often occur periodically; spontaneous remissions may interrupt active periods of pain, though about 10-15% of chronic CH never remit.[2] The cause has not been identified.
While there is no cure, cluster headaches can sometimes be prevented and acute attacks treated. Recommended treatments for acute attack includes oxygen or a fast acting triptan.[3] Primary recommended prevention is verapamil. Steroids may be used to prevent a recurrence until verapamil takes effect. The condition affects approximately 0.2% of the general population,[4] and men are more commonly affected than women, by a ratio of about 2.5:1 to 3.5:1.[1]
May 29, 2014 | Measuring Tools & Sensors
01 dodge dakota sport 4.7l replaced the passenger side head an used kerosene to clean the sludge wouldnt run right so i found that it was blowing engine fuses now its making a ticking noise whene i try to...
You replaced only one head-- why?
You had it reconditioned or installed a junk yard one?
Sludge is not good,it is a sign of neglect from day one,
when the vehicle left the assy plant
Can't guess at ticking noise from the internet
No idea how it sounded or ran before you took it apart
Blows what fuses & why?
I know your asking the questions, but you need to have wiring diagrams & ability to do some testing & should possibly have a friend with experience weigh in & offer some advice
May 10, 2014 | Cars & Trucks
Have a 2006 chrysler 300, 3.5 with loud ticking noise during acceleration, also experiencing loss of power. Replaced both rocker assemblies and performance improved but ticking is still there.
sounds like bad valve seats or seals do you have a oil pressure gauge on your dash.check the pressure.then check your return ports on top of the head thats giving you the problem see if the oil is returning to the oil pan.sometimes the return ports become blocked and the oil stays on top of the head.and see if the oil supply is making up to the head.hope this helps.mark
Feb 19, 2014 | 2006 Chrysler 300
Saeco xelsis leaking water
The removable drip tray inside the front of the machine has two rubber inserts on the back side and the rubber has come away from the plastic causing a false leak. You will need to order a new one or fix the existing one.
Nov 26, 2013 | Coffee Makers & Espresso Machines
Hi my estima is making a ticking noise when driving especially when slowing down or at stand still also the exhaust is rattling.i had a new one put on eleven mths ago.im going get checked but wondering...
I would suggest getting the areas between the cylinder head and the exhaust manifold checked for leaks. Your description sounds like a classic beginnings of an exhaust manifold gasket leak.
Aug 12, 2011 | 1994 Toyota Previa
I did all thing i could of to the car oil change spark plugs cables, head gasket sealer, and now after everything if it get to hot n if im driving then stop it stalls, and is making a sound like wen i turn...
Head gasket sealer? Sounds like you have a cracked head or blown head gasket. The ticking is probably from the valvetrain. If you have a cylinder head problem it will continue to run hot.
Aug 11, 2011 | 1988 Nissan Sentra 2 Door
My son has a 2003 Dodge Durango, while we were on the highway, we heard a ticking noise that sounded like a soft tap. We immediately pull to the shoulder of the highway to figure out what was happening,...
did you have the heads worked at a machine shop (pressure tested, valves seals replaced and ground , and milled )? also how many mies are on the engine? the ticking noise very well could be timing chain noise. as for the overheating did you check the water pump to make sure your getting proper circulation. you can test it by removing one heater hose from the intake then start the engine. if the pump is good then water should spray out of the hose if the pump is weak then the water may trickle out.
Jul 26, 2011 | 2003 Dodge Durango
How do i adjust my headlights ? they are tow low to the road on high beam
there are adjustment screws with an allen head right above, and rigt below the head light on both sides.
Feb 26, 2011 | Hyundai Tucson Cars & Trucks
1996 e350 got engine check light p1742 code
Call your local dealer with your vin # ,, there is a recall for that specific code.
96-5-16 • MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - CODE P1742 STORED IN MEMORY - NO DRIVEABILITY CONCERNS PRESENT - VEHICLES WITH E4OD TRANSMISSION BUILT THROUGH 10/15/95 • LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - CODE P1742 STORED IN MEMORY - NO DRIVEABILITY CONCERNS PRESENT - VEHICLES WITH E4OD TRANSMISSION BUILT THROUGH 10/15/95
MARCH 1996 PCM - MIL ON/DTC P1742 Set
Jul 29, 2010 | 2002 Ford E350
Computers & Internet Logo
David Payne
David Payne
