External hard drive emits noise and disconnects within 60 seconds
My LaCie 500 GB external hard drive (Design Neil Poulton model) used to work fine but now every time i connect it to any computer it will emit a rattling noise within 30 seconds and illegally disconnect itself within about a minute of that happening. This problem occurs whether i attempt to move files onto the drive or not! I am using a Mac with 450 GB partitioned to work on that and about 50GB available for PC compatible space. I have a Kanguru QS2 500g External Hard Drive that has a mind of its own. Sometimes it will make a beep and then disconnect itself. Following this, I usually have to connect and re-connect it several times before it stops doing this. Sometimes it works for a long period of time. However the main problem is that it can randomly disconnect at any time.
How can I make the connection stable and not have to worry about it randomly disconnecting?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Please try changing the hard disk compartment and thanks for your question
Posted on May 20, 2009
My computer is not recognizing my hard drive.
You will need data recovery help. This guy does it remotely and works off of donations. FreeDataRecovery.us
Jul 12, 2011 | LaCie Hard Disk design by Neil Poulton...
I dont see the drive in my computer
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 28, 2011 | LaCie Hard Disk design by Neil Poulton...
I have a lacie 500gig external hard disc and i fail the optimization and the disc shows only 9.9mb and i formatted in hope that will have the same setup assistant -but i turn wrong.Please tell me a...
click start control panel administrive tools computer management scroll to disk drives if you can see your drive right click select properties tools tools you should see click check now click start tick in two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box then wait for that to finish
also + to expand right click you should see options update driver disable uninstall scan for hardware changes
hope this helps
May 06, 2011 | LaCie Hard Disk design by Neil Poulton...
I need to install lacie stup assistant.or download
LaCie Setup assistant is made to make it easier for the customer.
If you do not have it, you can format your drive using your MAC or PC and you can download manual and utilities from the LaCie website, which are the only things the assistant really does.
Regards,
Jan 10, 2011 | LaCie Hard Disk design by Neil Poulton...
Lacie 1T Poulton design external hard drive is clicking
Before you resort to freezers and desperation, know that the external power supplies for these things are a. crucial and b. delicate. If the output voltage is down for any reason, it can produce the same clicking symptoms. I would get to a repair shop, and ask them to test the drive with a 'known good' power supply. I did so this very morning with a LaCie drive: no more clicking, happily mounting drive...and power supply replaced under warranty. Good luck
Feb 08, 2010 | Computers & Internet
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Lacie hard drive nonfunctional
I ran into this issue this week with my lacie big disk 500G external. Unit would power on when plugged into a pc blue light would flash and nothing no connection ding from windows.
Blue front light would flash repetedly slight ticking sound from drives but no connection i finally fixed this and gained access to my data by opening up the case and pluging my pc 12v connectors into both drives to power them up but leaving them connected to the lacie internals worked instantly and ive since copyed all my data off my 500 and will just transplant the drives to internal use on my pc. you cannot connect the drives internally and then copy the data due to the fact that they are raid 0 stripped drives so this hybrid setup works if your external case isnt powering up the drive correctly as mine wasnt.
Mar 02, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie Mobile 500gb not working
Just buy new external ( HDD ini is fine) just change the external for both off you
Dec 28, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Open Questions:
Getting Smart With: Toshiba Printer Contact Number 1888784-9316 For USA V If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Care, which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
May 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
210 people viewed this question
David Payne
David Payne
