Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Removing spray arm from kitchenaid dishwasher
  • 38 Answers
SOURCE: dishwasher repair
remove your filter and you will find something wedged in the motor housing make sure you unplug before you start work if not check the capacitor mounted on the motor good luck
Posted on Jul 21, 2007
jsrock516
  • 5911 Answers
SOURCE: spray arm not attached
You may have stripped the threads on the spray arm or spray arm support. I believe the threads are reverse-threaded and since they are plastic, can easily be stripped if turned in the wrong direction. This has happened to me before. The solution is to replace the lower wash arm and spray arm support. You can find the parts at repairclinic.com. Just type in you model number and look for item numbers 830883 (spray arm support) and 9040141 (lower wash arm). You may also want to check out searspartsdirect.com as well. The parts will be located under the "Lower Washarm and Strainer Parts" section. The two sites do offer comparable pricing. Post back if you need further assistance. I hope this helps you.
Posted on May 04, 2008
  • 949 Answers
SOURCE: Upper spray arm is not turning
Hi Chris,
It sounds to me like a restriction in the pump. I put together some information here on cleaning it out. If you try these please give me some feedback as to if they help or not.
Thanks!
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on Apr 25, 2010
  • 949 Answers
SOURCE: How do you remove the lower spray arm for a
I have put together instructions on how to clean out the sump area where the mascerator is on your model. Follow the link below and let me know if it is what you need.
KitchenAid Cleanout
Posted on Jun 21, 2010
  • 906 Answers
SOURCE: Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
I removed the lower spray arm on my kitchenaid dishwasher and cant get it to screw back in. Is there a trick to doing it? The arm was the only part I removed
My lower spray is connected by a large plastic screw type piece. Do you have that part? The arm itself just sits loosely on the base and the "screw" is needed to secure it. The arm itself does not screw on. If you lost that part, I don't know how you would secure the arm.
Jul 12, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
The dishes are not coming out clean.
remove the lower spray arm and the tower to the upper spray arms . Remove the top of the sump cover and clean out the sump. May be plugged with debris.
Dec 07, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Want to remove the spray arm and clean the filter
Below is a link showing how to clean out the sump area below the spray arms. If you want to clean the top filter when taking it apart, vinegar works to dissolve a lot of the deposits.
Sump Clean out
May 31, 2010 | KitchenAid 24 in. KUDU02FR Built-in...
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Spray arm doesn't turn
Probably blocked spray arms. Remove each spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results and the arms don't turn as well
Feb 06, 2010 | Dishwashers
My kitchenaid dishwasher needs the rinse aid refilled after approximately 2-3 loads. The top rack of dishes will be dirty, but the spray arm seems to be rotating? Any help?
Possibly needs a good servive. Remove spray arms and make sure every hole is totally clean. As well, take sieve out and pressure wash it as those holes are micro fine and if blocked, wont allow a full compliment of water to flow. see if it runs better after that.
Sep 16, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
good day,
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Upper two spray arms (Kitchenaid) are not rotating or spraying
I have had a similar problem. I found that I had to remove the spray arms and dislodge food waste that had gotten stuck in the nozzles. Whenever cleaning has been insufficient, this has always made things better. A shame that Kitcheaid didn't do a better job on their screens/grinder.
Mar 30, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
18 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
