Question about Brother MFC-290C Printer
Unable clean error 46
WAT SHOUL I DO PLS TO GUIDE ME WITH THIS PRIONTER
    Problem Solver:
  • 12 Answers
I think need to reset only by using code...
Posted on Jan 02, 2014
Mix-it-up
  • 832 Answers
SOURCE: clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Posted on Feb 10, 2008
  • 46 Answers
SOURCE: how to fix clean unable 46, pls tell me how
This is for the mfc5440 but should work I would really need the cleaning absorber pad replaced but takes a bit of getting to. - Machine off - Switch on the machine while holding down the ?menu?button until all the leds are flashing on/off. Now you are in ?maintenance? mode. - press 80 - press the ?mono start? button several times until you see ?purge: xxxx? - press ?2783? in order to reset the purge counter. You will see: ?purge:0000? - press the "stop" button. - press ?99? to exit the maintenance mode.
Posted on Jun 12, 2009
  • 13 Answers
SOURCE: unable to clean 46
Unable to Clean or Machine Error 46 means your purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET or OK
b. 0 then press SET or OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET or OK
b. 7 then press SET or OK
b. 3 then press SET or OK
This is to reset the purge counter. Then press stop
5. Using arrow up button look for the following:
a. 0 then press SET or OK
b. 1 then press SET or OK (To reset unit)
a. 9 then press SET or OK
b. 9 then press SET or OK (To exit Maintenance mode)
Posted on Jan 21, 2010
  • 9 Answers
SOURCE: clean unable 46, See Trouble shooting and routine
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Posted on Mar 26, 2010
  • 525 Answers
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Jan 23, 2011
"clean unable 46 " and see troubleshooting and routine maintenance chapter in users guide.
HI Gail,
Please watch this brother problem related video and solve your problem.
Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother DCP 165C Compact Color Inkjet...
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean error 46
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Apr 14, 2010 | Brother MFC 6490CW InkJet Printer
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
- ready to print
- CHEERS!
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean refer to maintenance guide 46
Hi
Thanks for using FixYa. Printer error 46 indicates that the ink absorber pad is full and required to be replaced by an authorized engineer. To resolve the issue please contact Brother Customer Service from "Contact Us" on their website—
Error 46 solution
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
Clean unable 46
Hi, check to see if there is any foreign object jamming the print mechanism, check all drive belts. If this doesn't show nup any problems, I'm afraid that you have a failure that will require dis-assembly and repair by a company who deals in these printers.
Apr 12, 2009 | Brother DCP 130C All-In-One InkJet Printer
Unable to Clean - What are the solutions?
plz search this forum for unable to cklean or error 46. ithas been described soooo many times.. :)
Apr 09, 2008 | Brother MFC 420CN All-In-One InkJet...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother MFC-290C Printer Logo
49 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
