Water won't pump
I just replaced one davey xj70 with a new davey xj70 because it stopped working. Motor wouldn't start. Installed the new pump as I have installed in the past. Found out that there is a valve that had to be removed from inlet, done that. the motor runs but the water stops after about 8 secs. any ideas what is wrong.
  • 1894 Answers
SOURCE: whirlpool calypso washing machine
if it stops and starts it coule be a power board problem
Posted on Jun 15, 2008
jsrock516
  • 5911 Answers
SOURCE: Replacing water inlet valve
First of all, UNPLUG the washer before attempting any repairs, and follow these steps:
1. You will need to remove the washer top panel by loosening the three screws in the back. With the screws removed, the panel slides back, then off.
2. Turn off the water supply valves and disconnect the water inlet hoses.
3. The inlet valve should be very simple to replace at this point. Disconnect the electrical connections and the hose(s) leading from the valve to the dispenser.
4. There should be a a mounting screw holding the inlet valve to the back panel. Remove the old inlet valve and install the new valve in the reverse order of the steps I just provided.
This is should be a fairly straight forward repair that anyone can accomplish without the assistance of a repairman. If you get confused along the way, please post back and let me know. i hope this answers your questions.
Posted on Jul 29, 2008
TheMobilian
  • 8220 Answers
SOURCE: Water keeps flowing does not stop---does not go thru cycles
You probably pinched the water fill hose that comes up from under the tub when you closed the cabinet. Also make sure it is free from trash in the bottom of the tub and that it is tightly connected to the water level switch.
Posted on Jan 06, 2009
  • 219 Answers
SOURCE: washer won"t fill with water
check your lid switch if its a top load
Posted on May 22, 2009
  • 185 Answers
SOURCE: Kenmore series 80, model 110-25842400, and serial
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Posted on Apr 12, 2010
Davey XJ70 pumps bore water but flow dwindles when garden hose attached thus requiring pump to be turned off to stop burn out. Marc
possible it is a jet pump that has a return hose back to the foot valve to assist the pump to lift the bore water higher to work the pump
if that is the case ,when you turn on the tap on the pressure to the lift jet is reduced and so the pump cannot lift the water from the bore --it runs out of water
the fix here is to restrict the flow out of the tap so that jet pressure is maintained--- don't turn the tap on more than 1 turn
the reason is the lift height is too great ,indicating that the bore water level is lower than it normally is
Feb 22, 2017 | Water Garden
Davey Water Pump XP350T with Torrium flow control won't run. We turn power on and it buzzes, then cuts out with a red fault light. Any ideas?
replace the failed start/run capacitor/s on the motor
town water although brown is filtered so unless a pipe has broken the problem will be the capacitor
May 30, 2016 | Washing Machines
Davey Pump won't start
Some of those have a safety switch if low on oil they want start.
Jan 16, 2014 | Davey Crickett High-Pressure Twin Impeller...
Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Mar 31, 2013 | Plumbing
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
1999 300M sometimes it won"t
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they just stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately, and a weak fuel pump.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from a Dealer, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
Aug 27, 2011 | 1999 Chrysler 300M
My waterpump was replaced in my concorde, drove vehicle home, now it won't start. What could problem be?
it could be the fuel pump that has stopped working and yes they stop this fast.it could be the timing belt has jumped you don`t say what motor is in this car,if its a 2.7 motor this can happen as the timing belt must be removed to gain access to the water pump,
Jul 05, 2011 | Chrysler Concorde Cars & Trucks
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
