Question about Vacuums
Kirby schematics Power Switch -120 V 110590
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Plug in kirby vac to do the floors and it won't start.
It could be the power cord or even the switch. I suggest taking it to an authorized Kirby repairshop and have it looked at. It could be something as simple the power switch
Aug 25, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby stopped working
Here is a guide to diagnosing a problem with your Kirby. I would imagine that your power cord has a short in it or the carbon brushes need replaced. You may want the take a look at my guide for replacing the power switch as well to make sure that it was hooked back up correctly.
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps...
Marci
Jun 15, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby won't turn on only when trying to use power nozzle
Make sure that your power nozzle has a little metal prong that plugs into the little rectangular hole in the fan case. If the prong is broken, you'll need a new nozzle. If the prong is intact, you'll need a new switch. Here is a link to help with the repair and help you locate the switch.
Hope this helps!
Aug 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 vacuum
check the cord. see if there are any frays. or broken spots. usually it is one of 3 things. 1, faulty electric cord. 2. the attachment or floor nozzle not being properly attached( kind of a duh issue LOL)
3. a faulty switch assy. the switch can be kind of a bear to replace. I hope it is the cord. if not i would take it to a kirby repair person, because it is very easy to damage the motor assy when replacing a kirby switch. trust me i have damaged a few learning how to do it
Jun 21, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G6 no power
Could be the switch, I would check the cord 1st. It has 2 wires running thru it, one may be open. That power cord goes bad often, if anyone is pulling on the wire rather then the plug, then it would have have stretched and break.
Jan 15, 2008 | Kirby G6 Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
