Question about Superex 50-373 2500 Watt 12 Volt to 110 Volt Power Inverter
2500 superex hooked up to 12v ,has a squeal when I turn a hair dryer, and the volt meader drops from 12v down alot
  • 41 Answers
Is the unit hooked up in a vehicle? If it is, try increasing the engine rpm a little bit to bring the voltage back up. Sounds like the hair dryer is overloading the inverter.
Posted on Jan 02, 2014
I have a Superex 100W power inverter. I want to see if I can plug into cig lighter then a standard extension cord and lamp into it
In order to produce 100 watts at 120 volts, the current will be 1.2 amps. But if you are producing that power from 12 volts input, the current will be at least 10 times the output current, and that would be at 100% efficiency, which is impossible to achieve, The efficiency could be assumed to be around 70% though, meaning that the current input required to produce 100 watts at the output would be somewhere around 13 amps. That's a lot of continuous power drawn from a cig. lighter, and the load might blow the fuse or breaker for that circuit.
Dec 29, 2016 | Superex Electronics - Others
Voltage gauge drops alternator squeals. When using plow
INSPECT BATTERY ELECTROLYTE LEVEL
INSPECT BATTERY CABLES/TERMINALS
LOAD TEST BATTERY,_______VOLTS @ 150 AMPS (Min SPEC 10.2 VOLTS @ 150 AMPS.)
INSPECT BELT(s),
TEST ALTERNATOR OUTPUT (ON THE VEHICLE,'NOT' BENCH TESTED),
1 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW not ENGAGED
2 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW ENGAGED ALT OUTPUT SPEC ????
Feb 04, 2014 | GMC Sierra Cars & Trucks
I have 2 new Whirlpool Estate Dryers and neither one of them will start. I have hooked up the wires (no ground wire-don't have in my house) and when I set the dryer it will not start. I looked for a...
do you have a voltage meter to test? you want to have 220 volts on L1 to L2.. this would be the red and black wires. this is where you need to have 110 volts, between L1 and N which should be white wire at middle of terminal block and 110 volts at L2 and N...this means your getting proper voltage to the dryer..if your not getting power on one side or the other..this is why its not running.
check this and let me know...there is alot of other things to consider if not this...
Feb 02, 2011 | Dryers
Nitro 483 amp where do you hook up the power it has a gnd rmt and +12v what hooks up where
Fused 12 volt power wire from the battery connects to +12V at the amp. Chassis ground wire connects to gnd at the amp. Switched 12 volt power wire (accessory) (remote turn on from after market radio) connects to rmt at the amp.
Jan 18, 2011 | Nitro BMW-483 Car Amp
Maytag dryer MDE7600AYW constant squealing when dryer is operatable.
Most of the time that squeal is the roller nearest the heating element.
To access the innards you first remove the door and the screws opposite the door for reversing purposes. This will allow you to pop off the front goalpost. Then you can remove those hooks that hold down the top. Then you remove the shroud. You can then get the drum out and inspect the rollers.
Manual and more HERE
Nov 16, 2010 | Whirlpool Dryers
Starter will not turn engine on 2001 tacoma
First, you need to check your battery with a volt meter to make sure you have 12v or better there. Then check that connection surfaces are clean and secure. Make sure opposite ends of both cables are also clean and secure. With volt meter across battery, turn the ignition key to the start position...volts should not drop below 9.5v. If it does, have battery load tested. If it passes, then either starter is drawing too many amps and needs to be replaced, or engine is seized (unlikely). If no drop noted, check voltage at large connection at starter (should be 12v) then, check small (trigger) wire on starter with key turned to start. If there is 12v there and starter does not respond, starter has failed. If no volts there, check neutral safety switch and ignition switch for volts in/out. Likely, before you complete these tests, you will have located the problem. If there is a "remote" starter relay in your system, check that for volts in/out as well.
Jun 08, 2009 | 2001 Toyota Tacoma
2500 dell inspiron fails to boot when new fan comes on
You are drawing too much current from the power supply with the current hungry fan.Try using a different fan that draws less power on start up. Or use a limiter to lower the input voltage draw on start up. These are usually found in fan speed controls You could also use a voltage dropping adaptor like the one use to quite fans down . They drop the 12 volt voltage to 7 volts by connecting the two voltages usually found on the power connector 12v and 5v and and adding them together getting a 7 volt output. You can also try connecting the fan directly to the power supply and avoid using the motherboard connector.The problem with this is you will not get use of the speed controling sensors used in the motherboard connections. Hope this helps you with your problem.
Apr 29, 2009 | Dell (6F858) Cooling Fan
02 escalade, vehical stalls at low idle
if it has over 40,000 miles on it change the drive belt and have the alternator tested and also make sure all of the vaccum lines are on and in place
Mar 06, 2009 | 2002 Cadillac Escalade
Green light, No Power
Disconnect the remote wire and make a jumper at the amp from the 12v + to the remote input and see if you get the same results. If yes, then you probably have a bad ground point. It might not be able to handle the transfer load it's receiveing. If no, then you have an issue with your remote wire or power wire. Check for any kinks or pinches in the wire.
Jan 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Superex 50-373 2500 Watt 12 Volt to 110 Volt Power Inverter Logo
193 people viewed this question
Top Superex Electronics - Others Experts
Are you a Superex Electronics - Other Expert? Answer questions, earn points and help others
