Question about Comfort Zone Infrared Quartz Heater
Product turns on makes clicking sound but fan not blowing out heat
This thing wont blowout heat
Honeywell TH6320WF when i turn system to heat and fan on auto it says heat on but never clicks on but then when i change fan to on the system clicks on but it seems to be blowing cool air
It sounds like the heat setting is not high enough. The heat setting needs to be higher than the indoor temperature or the fan will just blow non-heated air.
Dec 03, 2016 | Honeywell Heating & Cooling
Coleman/ Evcon central electric furnace Eb15b thermostat on auto will not blow air out i hear a click u see and feel it heating up then i hear Another click dont see nor feel heat then but put thermostat...
check the thermostat setting on back for electric heat. sounds like it is on gas heat. the fan should turn on right away if it is electric or heat pump.
Nov 15, 2014 | Heating & Cooling
94 thunderbird heat or cold air doesnt blow
if you saying the fan wont blow it may need a fan motor not uncommon it might be a speed switch if it has one some time you can hook a wire on the back of the speed switch plug in to get it on high use a 14 gauge wire or bigger a small jumper bent in a loop with the rubber peeled off the ends and shove them in the switch plug find the 12 volt ht wire on the plug with light or vom then try the other wires one at a time til fan runs with ignition switch on
Dec 24, 2017 | 1994 Ford Thunderbird
Ac fan wont blow
I would disconnect the fan connector and use contact cleaner to clean the connection. Usually corrosion. Also fan might be going bad (Common Problem).
Mar 27, 2013 | 2000 Saturn L-Series
Heat wont blow out
Most blowouts are caused by too little air pressure allowing the tire to flex beyond its elastic limits until it overheats.-----------------------------------------------------------------------------------
maxidas ds708
Nov 18, 2012 | 1992 Chevrolet Caprice
When heat on it makes a clicking sound then blows cold then clicks again then blows heat
Yah! I think you pressed mode button. If you press mode button it shows- Fan,Dry,Cool,Heat and Auto. You stop at your required mode.
Dec 12, 2010 | LG Heat cool Window Air Conditioner
Fan for heat and ac wont blow air. Makes A loud clicking sound
mcdevito75 here, The heater/Ac fan motor is a sealed unit, locate the fan motor, as you look at the engine from the front of the car the fan motor will be on your left side comming out of the firewall, It"s a round cylinder like and is black, from inside the car put the fan on, tap the fan motor itself with a screwdriver, small wrench, etc. see if it"ll start, if not have your local shop replace this fan motor.
Jul 05, 2010 | 1999 Ford Taurus
Comfort Zone Infrared Quartz Heater Logo
137 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
