Question about Insignia Televison & Video
Insignia plasma tv model #ns-51p680a12. after about 5 minutes the screen goes blank with volume still on. when i unplug it to reset the tv it displays the hdmi inputs in the top left of screen. what is going on? it does it constantly.
SOURCE: I have a a insignia lcd tv model ns-27lcd turns off by itself
check timer it may be set it will continue until its turned off
Posted on Sep 17, 2007
zjut
  • 106 Answers
SOURCE: Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Posted on Jan 01, 2008
SOURCE: Need Insignia TV code for my Sony Receiver Universal Remote Control
Try This link it worked for me.
www.insignia-products.com/universalcontrolcodes.aspx
Posted on Sep 20, 2008
  • 146 Answers
SOURCE: fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
Posted on Jan 30, 2009
  • 814 Answers
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Posted on May 23, 2009
After 5 minutes of TV being on screen turns grainy with vertical lines red and green and volume turns up real loud and sound is static. TV does not respond to remote control or power button. Have to turn...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 06, 2017 | Insignia IS-LCDTV32 32 in. Television
We have a NS-LTDVD 39-09 flat screen tv. Try to turn on and it trys but goes blank right away and turns back off.
Unplug it from power completely. Wait 15 minutes and plug it back in. If it still does it, you'll probably have to have the power supply replaced.
Jun 16, 2011 | Insignia Televison & Video
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
I have Insignia ns-p42q-10a tv, there is a loud hum when the volume is on when you mute the volume it goes away? Any suggestions?
check other inputs AVI, HDMI,,
do you here the hum on all inputs?
The hum maybe from a bad ground loop,, unplug all pluged in inputs, [dvd,games,radio,ect] <--check for hum.
If the hum is gone, plug inputs back in one at a time and test,,
When you find the source of the hum, go get a ground loop isolator to fix.
Mar 25, 2010 | Insignia NS-P42Q10A Plasma TV
Locate reset button on insignia ns-ltdvd 19-09, and the reset procedure to follow.
There is not an external reset button on this TV. To reset to factory defaults, enter the onscreen menu system and highlight the OPTION icon using the arrow keys. On the resulting screen, select "Restore Default." I would also recommend power-cycling (turn the TV off and unplug for several minutes) as part of your reset procedure. Additional details can be found in the owner's manual.
Mar 11, 2010 | Insignia NS-LTDVD19-09 LCD TV
Insignia NS-PDP50 Plasma TV - Remote Sensor failure
Change batteries.Reboot everythings.Tv unplug,replug couple mins later.Ur Directv box,push off/on for new update software.After that sould work.Rate me after u done this.
Jan 02, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Insignia TV model NS-LCD19. TV shuts off
Unfortunately your TV will need to be serviced. You may take the unit back to the retailer of purchase to arrange for repairs.
Sep 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia NS-8PDVD blank screen...
There is a switch on the side of the DVD player that reads "in / out".  Switch it to out and you should get the blue screen back.  It's a strange set up but this is how it works.
Dec 08, 2007 | Insignia NS-8PDVD
Televison & Video Logo
21 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
