Question about Dyson DC25 All Floors Bagless Upright Vacuum
Motor stopped will not restart - Dyson DC25 All Floors Bagless Upright Vacuum
  • 55 Answers
Check manual-- try another outlet- check the elect plug- think simple
Posted on Jan 02, 2014
Bissell vacuum 2 years old. Starts, goes for a while then stops. Have to wait before it starts again.
you are describing
motor over heating causing the thermal overload to click off
will only restart once cool enough
suggest the cause is
motor could be full of dust
clogged filters that allow motor to breath
motor bearings /bushes worn
motor past use by date
Nov 24, 2016 | Bissell Vacuums
Motor stops and won't restart until a cool down
Bushings or bearings in the motor are no longer good, heat up as the motor turns and seize up.
They are probably replaceable but if the shafts are worn or there is other damage to the bearing/bushing holders then you'll have to replace that too and you might consider getting a whole new vacuum for the cost.
Of course, unplug it before attempting to take it apart.
Oct 08, 2016 | Vacuums
No power what do I do when I stopped and tried ti start again no power . Emptied it and cleaned filter but still not working
All vacuums generate heat and some have automatic cut off switches when the vacuum does overheat. When this happens the manufacturer does not want you to just turn it back on, they want you to know there was a problem and to let it cool down. They often do this with a restart button. Having to press a restart button is supposed to make you think a bit more about the problem and, perhaps, let the motor cool down before restarting the vacuum. The button is often small and red.
Sep 15, 2014 | VAX Appliances Vax X3 Bagless Upright...
Lux classic vaccume keeps stoping
check all filters are clean, if ok check for blockages in pipes, it will stop if the motor overheat then restart when it cools down click on the link beloe to download manual if you don't av one,,
http://www.aerusvacuums.com/support/manuals/
Mar 26, 2013 | Electrolux Lux 5500 Canister Vacuum
Dc22 motorhead belt replacement
sounds like you may have debree caught on the belt shaft, causing motor to heat up and cease to work until cooled off. check motor shaft where belt attached to run wand head.
Apr 14, 2012 | Vacuums
Ran over a blanket that stopped the roller from turning. imediately I stut off switch and removed blanket (6" long wrapped inside, not a lot). After restarting the roller will not turn, and belt is in...
the belt is off the shaft of the motor.. take off bottom of vac.. belt around the motor shaft then the beater bar put the beater bar back into slots .their should be tension on the belt ,if not the belt is stretched get another one
Aug 22, 2010 | Vacuums
Blue Moon Miele power head stops intermittantly
It is not a solid short. This is caused by static arcing in the wand and in the connectors from base to hose. I was able to fix mine by smearing some dialectric grease on all electrical parts in the wand(especially by the led switch) and in the three prong connectors at the base to hose. Have not had nay problems since doing this.
Apr 15, 2009 | Miele Blue Moon Bagged Canister Vacuum
Panasonic vacume#MCV573500
it is probably a thermal issue. contact any local vacuum dealer.
Aug 15, 2008 | Panasonic MC-V7355 Upright Vacuum
Re: Rainbow E-series Cleaning System
Check the separator to see if it will turn freely, if not, take it off and see if the shaft will turn, if it does then the separator is causing a problem. If you can't turn the shaft, then there is a problem with the motor, and you will have to check the motor.
Jan 16, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Roomba
Mine did the same thing. I'm going to send it back for a warranty repair.
Dec 23, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Dyson DC25 All Floors Bagless Upright Vacuum Logo
87 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
