My nexus 7 says no command when I put in recovery mode
    Top Expert:
  • Computers & ... Master
  • 25,692 Answers
Ensure it is booting from the CD drive with your OS CD in it.
Posted on Jan 02, 2014
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
https://www.kingoapp.com/help/fastboot-mode.htm
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
May 11, 2016 | Tablets & eReaders
How can I transfer photos to my Toshiba computer?
Follow these steps to copy a file or two from your computer to the Nexus 7:
  1. Connect the Nexus 7 to the computer by using the USB cable.
  2. On a Windows computer, if the AutoPlay dialog box appears, choose the option Open Device to View Files. ...
  3. Locate the files you want to copy to the Nexus 7.
More items...
How to Transfer Files to Your Nexus 7 - dummies
www.dummies.com/consumer.../tablets/nexus-7/how-to-transfer-files-to-your-nexus-7/..and to put them from your nexus 7 to your computer just do the opposite.
Feb 28, 2016 | Google Nexus 7
How to remove a password from google nexus 7
I believe the only way to reset your password would be a hard reset. This will also remove all of data and return the device back to the original factory settings.
Reset your Nexus device to factory settings
Apr 22, 2014 | Google Nexus 7
Google support
Is this after serveral power-off and power-on attempts?
If so, you may need to reset it to factory defaults by entering "recovery mode".
Google "nexus 7 recovery mode" and follow the options within. All data on your nexus 7 will be lost.
Dec 06, 2013 | ASUS Google Nexus 7
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 tablet wont leave the startup screen. I tried a hard reboot but it stays on that screen and wont turn off
(enter BootLoader)
Step 6: Toggle with vol down CLEAR CACHE & reboot
Nov 03, 2013 | Google Nexus 7
I have forgotten my password for the nexus 7 tablet and need to reset to factory settings to gain entrance to tablet
Try the following:
  1. If your tablet is on, power it off.
  2. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power). You will see the word Start with an arrow drawn around it.
  3. Press Volume Down twice to designate Recovery mode.
  4. Press Power to restart into Recovery mode. You will see an image of an Android robot with a red exclamation mark.
  5. While holding down Power, press Volume Up.
  6. Use the volume keys to scroll to "wipe data/factory reset" and press Power to select it.
  7. Scroll down to "Yes - erase all user data" and press Power to select it.
Source: https://support.google.com/nexus/answer/2668187?hl=en
Hope that helps!
Sep 23, 2013 | Google Nexus 7
Nexus 7 wont turn on
You can try to do a hard reset by holding down the power button and the volume down button for 20-30 seconds. IF the device still will not turn on make sure it has enough battery or is plugged in.
If you still have problems you can try the following to do a factory reset:
Hope that helps!
Sep 02, 2013 | Google Nexus 7
Nexus 7 tablet mic doesn't work in portrait mode
The microphone for the nexus 7 is a small hole on the right hand side of the tablet, just below the volume button. Make sure your hand and any cases you're using aren't covering this when you're trying to do a voice search.
Apr 10, 2013 | Google Nexus 7
Nexus 7 16gb tablet won't power on
I would do a hard reboot. To do this you should hold down the vol up, vol down, and power buttons. This should bring you into recovery mode. Others seem to be having similar issues. Warranty?
Oct 19, 2012 | ASUS Google Nexus 7 Tablet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
