Question about Pool & Spa
Lanark spa bath. Air jets keep coming on and off all day and night.. No water in the tub. Air jets are not working when I'm in the bath. They stay on for a second only.
  • 3,103 Answers
Check the power system for a shorted or stuck relay..it may have broken springs..
Posted on Jan 09, 2014
4 Suggested Answers
alicantecoli
  • 22326 Answers
SOURCE: I have a new Pentair
difficult i know but all i would do here is to dismantle the pump and take it to specialist electric motor rewinder and ask them to have a look ,had quite a few problems like this of late and its down to made in china windings in the pumps ,they are nowhere near as good as a nice general electric made in the good old USA or a bosch or something made to a proper standard
Posted on Jan 15, 2011
uspartscente
  • 717 Answers
SOURCE: I have a Lanark double
fill the tub with water and then turn the pump on. Get under the tub next to the pump and loosen the union on the discharge of the pump until some water starts coming out. If you have an air lock this will relief that and the pump should start pushing water to the jets.
US Parts Center
Posted on Aug 22, 2011
uspartscente
  • 717 Answers
SOURCE: hot tub jets won't come on. Backlight on topside works and shows current temp. but jets or led lights in tub won't work. Topside panel buttons are dead. What is problem? Viking Royale spa
This sounds like a back circuit board to us.
rod
uspartscenter.com
Posted on Apr 09, 2013
Morgan spa diagrams
The water jets in most spas are adjustable so you can turn the water flow down to just a trickle if you want to.
You don't take current spa jets out of the spa. They are held in place by a couple of tabs. Through the years the chlorine/bromine will deteriorate those tabs and the spa jets will start "popping" out when the jets get turned on.
If you pull the jet insert out the socket they are in, you will ruin the jet insert and it will need to be replaced.
Rod
US Parts Center Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 13, 2014 | Pool & Spa
How do I get bad smell and crud out of jacuzzi jets
If you are experiencing a "smell" coming out of the water when you use the tub then you should use one of the products that are made for cleaning jetted tubs pipes.
Here is a link to a site that carries those items. These will get rid of the nasty smell and flecks of bacteria when you use the tub too.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Rod
US Parts Center
Mar 15, 2014 | Home
I want to clean the jets in my tub they look mouldy
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link at the bottom to the cleaning products I can find right now. There may be others out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Feb 27, 2014 | American Standard 9330.014 Adhesive Bath...
Lanark spa bath
Not really sure but it sounds like there is a sensor that may not be reading properly preventing the pump to turn on.
Rod @ US Parts Center
May 12, 2013 | Pool & Spa
I have a Lanark double spa with a Onga 23930 pump. The jets are not working and we think that maybe the pump has air in it. It is possible the it took air in when I was cleaning around the spa controls and...
US Parts Center
Aug 22, 2011 | Pool & Spa
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Stale water odour when jets havent been used on massage type spa
There are several cleaning methods on the internet. I would contact the maker of the tub and see if they have a cleaning agent. I know that Jacuzzi and Aquatic industries have a cleaner that works rather well. I have seen one on the net that uses 2 teaspoons of powder dishwasher soap mixed with bleach. I have not tried this one so don't know how well it works. The ones from the tub companies are not cheap, but if you want something that is going to do the job, spend the money.
Sep 28, 2009 | Hampton Technologies Hampton R -...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Aug 27, 2008 | Whirlpool Pearl Ballade True Bathtub with...
Pool & Spa Logo
100 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
