Question about Watches
Need to change the battery on my raytek ranger st
I have a S T Dupont oblong face with gold glitter in, with croco veritable strap. Battery needs changing but none of the jewellers and jewellery hospitals can get the back off, if there a knack to it.
To remove the back, you must first remove the leather strap. Between the lugs on the case, you will find 2 small screws. Remove these and the back will come off with ease.
Jan 03, 2011 | S.T. Dupont Watches
NEED AQUALITE MANUAL - CAN'T SET TIME
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press any button on the watch.
Apr 09, 2010 | Watches
NEED THE INSTRUCTIONS FOR AN AQUALITE 100 jstreiter@comcast.net
To set time:
To set Alarm time:
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Mar 26, 2010 | Bulova Watch
Digital umbro watch purchased 2001.How to change time please. 2 buttons on left. top light, bottom mode. 2 on right, top st/stp, bottom reset.
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Thanks!!
Oct 06, 2009 | Bulova Watch
Adventure tech doesn't have chime
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: info@goamfix.com
web: www.goamfix.com
Sep 14, 2009 | Timex Expedition Adventure Tech Compass...
Need a battery
if you are in chicago Illinois we do change battery for ebel watches
other wise any expert watch maker will do that.
203 N. LaSalle St
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 13, 2009 | Ebel Classic Wave 9090F249725 Wrist Watch
I cannot get the back of a watch on after changing the battery. What can I do?
You need specail Case press to close it
I suggest take it to Jeweler or watch repair shop
hope this info help
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
Aug 22, 2009 | Watches
I NEED A BATTERY FOR MY LOCMAN MARE WATCH..WHERE CAN I FIND FOR REASONABLE PRICE
We change this watch battery for $25.00
if you are in chicago most welcome to our store at
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
Aug 21, 2009 | Watches
Changing the time on an LCD Digital Watch
Malcolm S
Feb 29, 2008 | Watches
Watches Logo
20 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
