Question about Whirlpool GT1196SH Microwave Oven
Need a new microwave to replace the old one
Is. There another microwave that has the exact same dimensions as I need to buy a new one to replace the old microwave.
What are the dimensions of a kenmore microwave with model number 565.66401690?
best bet is to take a tape measure and measure the width , the height and the depth, write down those measurements then go to an appliance shop and measure all those on display
Dec 09, 2015 | Kenmore Microwave Ovens
Microwave runs but will not heat(unit is approx. 5yrs old)
the problem may be with your thermostat check that ,and repair it
Jul 03, 2008 | Microwave Ovens
I'm trying to convert a over the range frigidaire microwave that is 30" by 15.5" by 15" into cubic feet.
generally speaking you buy and OTR microwave by width, i.e., 30" wide is the standard width of all most all OTR . so any 30' wide microwave will fit. when talking about cubic feet, they usually are talking about the interior capacity of the microwave. but if you really want to know cubic feet of above dimensions, then multiply all three together and divide by 1728. (4.036 cuft)
Aug 29, 2015 | Frigidaire Microwave Ovens
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
Jan 15, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
I need to know the dimensions of a sharp r-1471 microwave. Mine has stopped working and I want to make sure the replacement will fit
29 15/16" W X 16 3/8" H X15 1/4" D (outside dimensions)
I copied this from my Sharp Carousel Operation Manual as I just
had to replace my 13 year old microwave.
Apr 04, 2012 | Sharp R-1480 Microwave Oven
I have a 20-yr-old microwave--a kenmore 565.8824581--that just suddenly stopped working. no lights, nothing. offhand do you think this might be a fuse issue that is fixable, or would this simply warrant...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 21, 2011 | Microwave Ovens
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool GT1196SH Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
