Question about Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive
External Hard drive not showing in my computer
I have an external hard disk. it was working for more than six months and now suddenly it doesnt work. when i connect to my pc the light on the hard disk comes on but it doesnt show in my computer. please help.
  • mark
    mark May 11, 2010
    quick question what would your operating system be on your pc
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Thanks for your question...
please change the hard disk compartment and do it carefully.
Posted on May 20, 2009
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
Its not getting recognized it doesnt show up in the desktop
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Take care
Jan 08, 2010 | Computers & Internet
External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 24, 2009 | IBM TravelStar 48GH 48 GB Hard Drive
Computer doesnt read the external hard drive anymore
It sounds like the hard drive head crashed when you pulled the power plug. Unfortunately if you can't get drive to be recognized, you won't even be able to run any diagnostics. You will have to take the drive to an authorized repair shop who will have to check the electronics to see if the head will respond. Unless you have data on your drive that you absolutely need, you will probably save a lot of money by replacing rather than repairing the drive.
Jul 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Malfunctioning WD passport that windows doesn't detect.
Inside the case is a regular laptop size harddrive.
Laptop harddrives are 2.5 inches across. (2-1/2 inches. Desktop harddrives are 3.5 inches)
I would suggest the external enclosure the harddrive is in, is defunct.
I would suggest buying a new external enclosure, and putting this harddrive in it. Then just plug the USB cable in, (As you did before), and download your data, to be ready to transfer.
You need an external enclosure that is Sata, and is for a 2.5 inch harddrive. These are relatively inexpensive.
Let me show you some examples:
1.http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2783&name=2.5-eSATA-Hard-Drive-Enclosure&Nav=|c:2781|&Sort=0&Recs=10
May 10, 2009 | Western Digital Passport WDXML800UE...
My iomega hard drive is dead how can I fix this?
Disconnect any leads and remove the outer cover.
Check the hard disk inside is securely pushed into the receiving socket.
Replace outer cover and give it a try.
Sometimes a knock can dislodge the drive and cause the problems you describe.
Best wishes.
Mar 03, 2009 | Iomega (33600) 160 GB USB 2.0 Hard Drive
External doesnt show on my computer
i fixed my problem by going to the western digital site and downloaded the installation package. i installed it and next thing i knew it started working again. hope that may help if anyone runs into a similar problem
Dec 28, 2008 | Western Digital My Book Essential Edition...
Turns on but nothing else
I have been using this hard disk for about 6 months now. It stopped working. The power and the usb cable are connected. I use Windows Xp and it doesnt read it. And for some reason most of the time when i open 'my computer' and the hard disk usb cable is plugged in 'my computer' stops responding !! However the 'safely remove disk' icon comes on the task bar and i can remove it from there. But i cant read it from explorer. The light on the HD keeps blinking. It reads my friends HD and flash drive. Please help me.
May 23, 2008 | Western Digital My Book Essential 500GB...
Transcend 8GB SSD, 2.5- Inch, IDE, SLC Hard Drive Logo
189 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
