Question about Hotpoint Ultima WF860 Front Load Washer
Hot point f-08 fault code
As cycle completes machine stops with fault code f-08,we have no instruction manual and is oing our heads in,clothes come out completely saturated.it is not so bad on a 30 min cycle
  • 2 more comments
  • Anonymous May 21, 2009
    washed fine earlier put 2nd load and f08 came on washing absoutly soaking hotpoint wt960
    hotpoint f-08 ....I have the same problem can this heater part be replaced without calling an expert out.
  • redshazbabe May 24, 2009
    i have the same problem it is something to do with the heating thermostat. had a repairist out to our machine and he put a new thermostat in but it still came up with f-08 got to go out and buy a new washing machine now
  • Anonymous Mar 30, 2014
    Doesn't matter what program is chosen , just restarts about half way through and the time runs down to complet
  • Hotpoint Master
  • 3,463 Answers
F08 means that the heater relay cannot be activated.
Suggest you check heater, and or thermistor (thermostat) for a fault, replace as req'd.
Please rate my solujtion.
Thanks.
Posted on May 20, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
All wash cycles keep prematurely stopping. I am not getting any error codes.
The programmer itself might be at fault
No cycles complete .... but does the machine stop at the same part of each cycle, i.e. the rinse or the spin. If it does you can
ascribe the fault to a particular component.
If it is stopping at different points it would probably be the programmer.
A technician should be able to definitively diagnose the fault
Jun 22, 2015 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Hotpoint Ultima WT721 F 08 fault code
Try the brushes first. I'm guessing the carbon deposits on the floor are from the brushes.
Nov 16, 2013 | Washing Machines
No hot water cycle on ge wcvh6260fww
You need to replace the water inlet valve. Here is the part to order.
I have the complete service manual available if you should need it, post your email address.
Feb 17, 2013 | GE WCVH6260FWW
Hi I have a Maytag model fav6800aww stopped in mid wash cycle,now if you try any cycle it makes a whirling noise for a few seconds then goes to the light flashing pause mode.Thanks.
No erro codes to the console correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual
Sep 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fisher & Paykel GW709NZ will not fill
Hi just read your posting.Your Error Code is 49.This means you have a Water Valve Fault.Would you like me to guide you throe the testing and repair of your machine?If you do then have you or can you borrow an electrical test meter to test the water valves?Please reply and tell me how you would like to proceed.Looking forward to your posting.
Jul 19, 2010 | Fisher and Paykel Washing Machines
Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Jun 18, 2009 | Kenmore Washing Machines
Hot point washing machine has a symbolF-08)
F08 means heater relay cannot be activated..
Usual cause is faulty heater.
If you are able check the heater for continuity or an earth fault, then you will need a meter to do so.
If the heater and thermistor check out o/k, then you are probably going to have to call an engineer..
Please leave feedback.
Dec 07, 2008 | Hotpoint Washing Machines
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Hotpoint Ultima WF860 Front Load Washer Logo
1,685 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
