Omega Technowash Dishwasher. Model DW 2005 WH.
The electro-mechanical timer stops just after the dishwasher powder is released and again near the end of the cycle. Also the water is not heated and no...
Hi
You most likely have a fault with the Thermostat. That is common on Omega Technowash which is similar to a Smeg dishwasher. More often than not the Thermostat fails rather than the heat element. However, not to completely dismiss a failed heat element.
The thermostat is not very expensive. If you don't have the means to test the element or thermostat via a multimeter, you can order the thermostat to have a go at fixing it yourself.
Unplug the machine from its power point.
"Two screws in the front kick plate. Open these and lift off kick plate. When you open the dishwasher door you will see an L-shaped heat element which is on the bottom of the bowl on the left and back of machine. The Thermostat is the round metal head situated on the front left in between the element coils. When you look from underneath inside where you have removed the kick-plate you can see two wires going to your heat element and 4 wires going to the Thermostat (either 2 White and 2 purpule) or (2 red and 2 white).
The thermostat is pushed in from the bottom and sits in a groove of a rubber seal. You can pull it down and out from underneathe and twist and push up the replacement in its place. Make sure the sharp metal edge of thermostat is poped insided the groove, otherwise the machine will leak.
Try this first, I am fairly sure it is the thermostat. If you have a multimeter you can check continuity of the heat element.
If you think this solution helped you please vote 4 thumbs up and give me a testimonial.
Thanks
Ash
Sep 22, 2011 |
Dishwashers
