Question about Electronics - Others
Internal high definition audio
What means internal memory on photo
  • 289 Answers
Internal memory would be a non-removable type that is built into your camera. External memory (i.e., SDHC cards) allows you more storage depending on the amount of . All you need to do is insert the appropriate memory card and you are good to go.
Posted on Apr 30, 2014
I have formatted internal memory and lost photos from camers
Formatting generally does that. Check to see if there is some software that can restore them. If the area where the photos were has been overwritten by other files then the answer is definitely no.
Nov 03, 2015 | Agfa DC-1030S Digital Camera
My photosmart will not print a picture. It printed 3 (all from the same source) then it says "cannot display this photo" for the 6 others (from another source) I checked, files are all JPG (all 9)
Maybe the pictures are too high a resolution. Meaning they are too big for the printer to capture in it's internal memory. Try resaving the picture smaller and try a re-print. Cameras today take picture in high definition but printers don't usually get sold with a lot of memory. The computer can usually spool up the pictures but again asking the printer to capture and resize the picture1 (800) 448-6262 is usually asking a lot from a printer. Just try resizing a picture to a smaller format then try and print it.
Jan 17, 2015 | HP Photosmart A617 Compact Photo Printer...
Internal memory
Information is not clear; however, if you mean to clear contents (photos, movies) from the internal memory, try the following.
1. Switch off, remove the SD card, re-start the camera.
2. Switch to playback mode; there you will find the photos/ videos stored in the internal memory. Manipulation of those media is normal.
Aug 30, 2014 | Kodak SLICE Digital Camera
Camera will not record, just stops after one second, and photo's dont save. I have tried it with 2 cards that work in other cameras but won't do a thing,
Your internal memory is corrupted. Formatting your internal memory should solve this problem. Remove your memory card. Click on "my computer," click on "removable disk," click on "format." After formatting, reinsert the memory card and your camera should work fine.
Aug 24, 2011 | Kodak PLAYSPORT High Definition Camcorder
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Camcorder keeps reading internal memory full and just put new memory stick in camcorder how do I get out of internal memory
Your Sony camcorder has internal hard-disk and records by default to this media. If this is full, you need to offload the recordings and free up some space on the disk. But to select the memory card you can do the following:
Selecting the recording media for movies:
Touch (MENU) [Show others] [MEDIA SETTINGS] (under
[MANAGE MEDIA] category) [MOVIE MEDIA SET].
The [MOVIE MEDIA SET] screen appears.
Touch the desired recording media.
Touch [YES] .OK
The recording medium is now changed.
For still images:
Selecting the recording media for photos
[MANAGE MEDIA] category) [PHOTO MEDIA SET].
The [PHOTO MEDIA SET] screen appears.
Touch [YES] .OK
The recording medium is changed.
Hope this helps, if more help needed, reply back.
Apr 12, 2011 | Sony Handycam HDRXR350E High Definition...
Can you recover digital photos that were saved on the internal memory - but accidentally deleted?
You may recover photos from camera with asoftech photo recovery which helped me before. You can download trial for free
http://download.cnet.com/Asoftech-Photo-Recovery/3000-12511_4-10913438.html?part=dl-10913438&subj=dl&tag=button
Please be noted that your camera memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Feb 15, 2011 | Fuji FinePix S2000hd Digital Camera
Audio device on high definition audio bus is missing on my computer.its manufacturer is generic usb audio and location is location 65535(internal high definition audio).please help me reinstall it.my...
go to the web site of your computer manufacturer or audio card vendor to look and download the sound card/audio driver. If you use a laptop, try to also make sure you install the available modem driver if applicable and the last video driver. You can also go to http://support.microsoft.com/kb/888111 to downlooad the audio patch from Microsoft
Oct 08, 2010 | Computers & Internet
Screen says internal memory is full. how do you clear the internal memory
Hi there internal memory means inbuilt memory. When you click the snap all photos are save in your camera internal memory. I hope you use external memory card. Go in settings and select the memory card( external) for further snaps. Then the message did not come again until full the memory card. And if you want to clear the internal memory card then connect your camera with your PC then copy the all photos from the camera & paste in computer. After that go inside the internal memory of camera via computer & delete them. Then your camera in build memory card will empty. I hope you understand . If you have any question then ask me. Thanks & waiting for your feedback.
Apr 03, 2010 | Kodak EasyShare V1073 Digital Camera
Audio not working and bought the computer with sound
Audio not working means there must be a driver problem.Try to install the audio driver again.If it is high Definition audio driver first uninstall audio driver and high definition audio driver package.Reinstall the driver again.if problem persists check for the audio port.
Jul 05, 2008 | Acer Aspire™ T180 PC Desktop
Electronics - Others Logo
37 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
