Question about Bissell 3624 SpotClean Pro Portable Spot Cleaner
My bissell 3642 spotclean pro leaks around the "Suction Gate" while in use, leaving a dirty, wet spot on my carpet. I have removed and cleaned around this part, as directed in the user manuel. It cont
My Bissell 3624 Spotclean Pro Portable spot cleaner peaks around the " Suction Gate", while in use. I have removed and cleaned this part, as directed in the user manuel, but the unit continues to leak onto the carpet, while I am cleaning a spot. How can I fix this?
3 Suggested Answers
SOURCE: Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Posted on Jan 14, 2009
heatman101
  • 43501 Answers
SOURCE: my bissell carpet cleaner won't dispense the
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdghd
Posted on Sep 30, 2010
Bissell spotclean pro hose assembly replacement
bissell customer service or ask a vacuum repair shop
Sep 06, 2016 | Bissell SpotClean Professional Portable...
My bissell proheat blows dirty water out
sounds like it is cracked or a sea or, washer is bad and needs repair but if it is clogged or just needs cleaning and tightening it can be the way to go and fix it.
watcha few videos and check your own out:
and
https://www.bissell.com/proheat-2x-pet-carpet-cleaner-9200p/how-to-clean-your-proheat-2x-deep-cleaning-system
and
How to Clean Bissell ProHeat eHow
Jul 12, 2016 | Bissell SpotClean Pro Cleaner
Clean bissell spot bot brush
NONE of these answers apply to the question! The asker referred to the Bissell SPOTBOT, which doesn't have a push handle. I'd like to know how to remove the brush myself. I know how to remove the components but haven't been able to figure out how to remove the mechanism.
Mar 12, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell Pro Heat 9200 dirty water dripping out
heatman101
rujr
Mar 20, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell proheat 2x leaves dirty water spots
Your belt for the brush might need to be changed, that or the suction parts is clogged with hair or fuzz, check that clear part of the front of the machine to see if theres anything clogging it
Sep 14, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Spotbot is leaking...
Mine constantly leaked as well but I found that if I remove the container will the solution in it after every use it doesn't leak anymore. I store my container (upright - nozzle face up) under the sink with my other cleaning products and when I need to use the machine I pull it back out, pop it in and clean.
HTH
Dec 28, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell 3624 SpotClean Pro Portable Spot Cleaner Logo
133 people viewed this question
Top Bissell Home Experts
Lawrence Oravetz
Joseph Coppeto
Joseph Coppeto
Are you a Bissell Home Expert? Answer questions, earn points and help others
