Question about Singer 5050 Mechanical Sewing Machine
When I embroidery bobbin jams
Everytime I try to embroidery something the bobbin jams and I have to take the whole thing apart to readjust bobbin case and all. sewing doesn't do it, just embroidery.
    Champion:
    Habit-Forming:
  • 201 Answers
Please you buy a new model embroidery machine.
Posted on Jan 02, 2014
dupina
  • 110 Answers
SOURCE: Bobbin case
If your machine is older than 18 months, it needs a free upgrade from your dealer. The plastic see through needle plate needs to be replaced by a newer version that will keep the bobbin down. Further more a bobbin case position finger needs to be installed.
Posted on Nov 13, 2007
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
kent581
  • 87 Answers
SOURCE: bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Posted on Mar 18, 2009
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
The machine is locked up. I've tried checking for thread behind the bobbin case, but cannot get the bobbin case to move.
Check your owner's manual troubleshooting section.
Assuming the machine is jammed with thread:
Try removing all the thread, remove the needle, the presser foot and the needleplate (if it is removable). If there is a thread tangle in the bobbin area, try to snip the thread loops and gently pull with tweezers or needlenose pliers. The best thing would be to get the bobbin case out of the machine. Once the bobbin case is out, the thread should be pretty easy to remove.
Oct 22, 2015 | Janome MB4 Four Needle Embroidery Machine
Thread breaking
Can you please tell me what is the model no. and the brand so that i can help you fix the problem.
Waiting for your reply..
Feb 24, 2008 | Singer CE-200 Quantum Futura Computerized...
The plastic bobbin is stuck in the steel bobbin case. I can not get it out to reload the bobbin.
not a good thing but try putting the whole thing in the freezer for awhile . will make it shrink and perhaps just fall apart
Mar 21, 2015 | Sewing Machines
Bobbin case jams
There are several things that can cause that, and you need to investigate and eliminate the possibilities one by one. First, you need to clean both the upper part of the machine, as well as the bobbin area. Take a look at page 80 of your user\'s manual for instructions on removing the cover over the thread path--it\'s a simple matter of removing two screws, and it\'s designed to come off for cleaning. Raise the presser foot, and use ONLY unwaxed dental floss or hand embroidery floss, and floss between the tension disks--there may be lint and/or loose threads preventing the thread from seating. If you\'re unsure regarding the disks\' location, just raise and lower the foot several times--it\'s the only thing that will move. By the way--you DO thread with the presser foot UP, don\'t you? It\'s the only time the disks are spread to accept the thread and exert tension on it, and may just be your problem.
Next, take out your user\'s manual review how you put your bobbin case in, making sure that the pointy part of the case is against the spring on the bottom right. Also make sure that the spring (called a "cushion spring") has not popped out. I\'m going to upload a photo of the case with the spring out and properly in with an explanation.
You should be cleaning your machine--top and bottom--as well as adding a drop of ONLY sewing machine oil in the center hole of the bobbin basket for approximately every 5 hours of embroidery sewing. Clean out the bobbin basket (holds the bobbin case) with the tiny brush that came with your machine, or with q-tips moistened with one drop of sewing machine oil, making sure that you get under the lip of the basket.
Review with the user\'s manual how you thread the bobbin in the case to make sure tension is being exerted on the thread.
Dec 13, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
New Singer 1507 user - cotton jamming everytime
try this link for a free manual just in case you don't have one
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
if the fabric is real light weight you may have to use a stablizer
also check to make sure the needle is the right one for the fabric being sewed..
make sure the bobbin is turned the correct direction, try putting the bobbin in the opposite direction..
if the machine keeps jamming, take it back up where you bought it and show them what it's doing and see if they can help you..
Jun 20, 2013 | Singer 1507
Brother sewing machine jammed?
take bobbin out...look in case in machine and pull any loose threads...you have to sew very slowly so this does not happen...the books don't tell you that!!! Make sure bobbin itself is neatly wrapped and thread is out where it is supposed to be once inside case.
Apr 04, 2013 | Brother LS-2125 Mechanical Sewing Machine
Machine jams after 4 or 5 stitches. Bobbin thread locks up.
try these suggestions
change the needle
make sure the thread doesn't come off the thread take up lever--this
can jam the machine
make sure the bobbin is turned the right way in the bobbin case--this
can cause problems if the bobbin is turned the wrong way
make sure the bobbin is not warped or damaged
make sure there are no burrs in the bobbin area or on the needle
plate
Oct 16, 2012 | Singer 8280 Mechanical Sewing Machine
Janome 10000 bobbin case problems
make sure you hold the cotton so it doesn't go under and ball up
Feb 03, 2009 | Janome Memory Craft 10000
Singer ce-100 futura
Hi justmewynn, The url I am adding to this post may be of help. It is a pdf file from Singer contain many diagrams of the CE-100. Maybe you cqan page through it and find what your looking for. Hope this helps you. http://www.futura-support.com/files/CE100-Eng_Fre_Spa-77153.pdf
Sep 27, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer futura ce-100 embroidery machine
Under the embroidery attachement (on the front side) is a lever to engage or disengage the "feed dog control." When embroidering, you need to move the lever to the level to disengage. The feed dog control should only be at the righe side position, or raised when you are not using the embroidery attatchment.
Jan 31, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer 5050 Mechanical Sewing Machine Logo
48 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
