Question about Advent 4211c Notebook
Inability to "save" on one of my 2 memory sticks.
Message box "Word cannot complete the save due to file permission error. (E:\"NAME OF FILE.doc")
I then am forced to save on my alternative memory stick.
    Master:
  • 409 Answers
You have probably just filled the memory stick.  or set it to read only.  does it have a little switch on it's side?
Posted on May 20, 2009
When I attempt to open a word document, I get a error message
You made a backup? If yes, then:
Start MSWord.
Click the Microsoft Office Button, and then click Open.
Locate the folder in which you last saved the missing file.
In the Files of type list, click All Files. The backup file usually has the name "Backup of" followed by the name of the missing file.
Click the backup file, and then click Open.
Otherwise it is necessary to try only this way:
DOC Repair Kit is a comprehensive Microsoft Word DOC repair tool with immense potential and an interface that makes the entire procedure a snap. Based on a lightning-fast proprietary core, the program knows how to repair Word DOC files in situations when other tools appear completely helpless.
For more information: http://www.doc.repair/
If this way didn't work, try to find the answer here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/word/392-how-to-repair-word-after-the-file-is-corrupted-and-cannot-be-opened
Oct 27, 2014 | Microsoft Office Word 2007 Full Version...
I am not able to backup error code is 80070005 my os is windows vista home basic
In order to find the root cause of this issue, we need few more information.
a) Are you performing a complete PC backup?
b) Do you have complete file permission to the files you are backing up and to the destination you are saving the back up?
As a workaround you need to follow the steps provided below.
Check the permissions of the file or of the folder the file is saved in. Here's how:
1. Right-click the file or folder, and then click Properties.
2. Click the Security tab.
3. Under Group or user names, click your name to see the permissions you have.
To open a file, you need to have read permission.
Check to see if the file is encrypted. Here's how:
4. Right-click the file, and then click Properties.
5. Click the General tab, and then click Advanced.
If the Encrypt contents to secure data check box is selected, you need the certificate that was used to encrypt the file to open it.
Jun 02, 2010 | Microsoft Computers & Internet
I've been getting pop-up windows that say I am prevented from opening or changing documents/files due to lack of authorization or permission. I am the owner of and only person using this computer. How can...
I am not sure if the documents or files that you are opening or changing are from attachments sent to you via email or not, but I can suggest that you can try this step:
Right click on one of the affected files and select Get Info.
This will open a long narrow box providing detailed information of the document.
Now look at the bottom of the window under Sharing & Permissions
Click the padlock and enter your User Admin password when the pop up window appears.
This will allow you access to changing the current permissions of this document.
Make sure you see permissions for "Read and Write" attached to your user name.
If you do, then go ahead and close this window. However, if you see only Read permissions attached to your user, then change that to Read and Write.
Once you have done this, close this Get Info window.
Try to launch that affect document to see if it opens now. If it does then this may be a permissions issue that is affecting your documents and files.
Whether you can or not, I would still recommend you still run this procedure below in order to try and fix this permissions issue.
Now run Disk Utility to repair all permissions on your Mac OS X volume.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} -RUN DISK UTILITY-
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utilities run this repair permissions until completion
Once Disk Utility is complete and there are no errors in red in the completion summary (if there are errors listed in red, re-run Disk Utility to see if those error will clear- if they don't reply back to this post right away and let me know what the exact error message is), quit Disk Utility.
• Now attempt once again to access the affected documents and files and see if you are able to access these items now.
I hope this helps.
Regards,
-Mactechtrainer
Feb 06, 2010 | Apple MacBook Pro with 17" Display
Cannot save to my Kingston usb
maybe your file permission is read only. Go to my computer, browse your file. Right click and choose Properties. Uncheck the Attribute
May 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
File permission error when saving in Word 2007
This error occurs when you are in a domain, and the files came from other users.
What you can do is right click a folder or a file > properties
look for the security tab then, add everyone on the list. And make sure that you check full on the permissions.
you can get back to me if this doesn't work.
Mar 03, 2009 | HP Pavilion dv8000t Notebook
Get 'file permission error' when I try to save in Word.
This error means you dont have suffecient priviledges to save. It sounds like you need to be logged into an Administrator account. If you are, Right click the icon for the flash drive, And click Run As Administrator
Jan 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Error -37
Hi, sorry you are having problems,
Well, here is what error -37 is: Code: error -37 bdNamErr Description: Bad file name (File System Error)
Basically, it is saying you cannot save a file by that name in that place....
Did you try saving it elsewhere on your Mac, like on the desktop ?
Just a side note, Apple stopped development on AppleWorks some time ago ( 3 years ) in favour of iWork. I highly recommend getting the newest version of iWork 09, it's compatible with all your Works documents and is really built for MacOS X 10.5, Leopard.
What do you mean whe you say “ Before I reimaged the machine ..” ?
Dec 23, 2008 | AppleWorks 6 for mac
File/Folder Permission Message in Pinnacle Studio 11 Plus
Hello welcome to FIxya!
Here you can check this procedure on how to open your files again.
"1) Check your Recycle Bin
2) Do a Folder/File Search for each of the Grey Folder Project names. This will display all Folders & Files with that Project Name. You are looking for an .stx File. If it's there, right-Click on Project Name / Open Containing Folder & Copy it to your My Projects Folder. Then you should have both the Grey Folder & .stx File for the same Project name, showing in your My Projects Folder.
If the Search doesn't display a .stx File, you can create a new one, by Opening a New empty Project, which will create a My Movie Grey Folder & a My Movie .stx File, Save to your My Projects Folder. Delete the My Movie Grey Folder & Rename the My Movie .stx File to the same name as your original Grey Folder."
So ...after finding my "lost" movie file, with its file name, under Documents\Pinnacle Studio\My Projects i then went through the following procedures using your great advice Colour;
  1. Make a copy of your found "lost" movie grey film icon file by right mouse clicking on your lost file and choosing "copy". Paste the copy into another folder in Documents where you can find it if need be
  2. Then go back to Documents\Pinnacle Studio\My Projects and right mouse click onto your grey film icon. Choose "rename". Then rename your "lost" grey film icon to a new file name but do not put .stc at the end of the file name, if you are operating VISTA and Pinnacle 12. This is important because Pinnacle 12 won't recognise the file later if you have .stc in the file name
  3. Open Pinnacle and go to the File Menu
  4. Click on New Project
  5. Open File Menu again and click on Save File as
  6. Give the file a name such as "Movie 7" and save it
  7. Close out of Pinnacle
  8. Open up Documents\Pinnacle Studio\My Projects and observe that you now have 2 new files there ...a grey film icon file saying Movie 7 AND a coloured Pinnacle icon file saying Movie 7
  9. Delete the grey icon file with the file name Movie 7
  10. Now give your coloured Pinnacle icon file the exact same rename as your precious "lost" renamed grey movie icon file, using the right mouse click on rename proceedure as explained in No.2 above.
  11. Close out of Documents file
  12. Now open up Pinnacle again
  13. Go to Menu and choose Open Project
  14. There you will see the coloured Pinnacle icon file with the new name of your "lost" movie file.
  15. Click onto its coloured Pinnacle icon, and watch your "lost" movie come into view again
Nov 16, 2008 | Pinnacle Studio Plus Version 11
MS word 2003 files not retreivable from Cruzer 8GB
I would suggest copy the file ot yoru desktop and open it from your desktop.
Nov 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Advent 4211c Notebook Logo
97 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
