Question about RCA Televison & Video
Sync a zenith remote to a x19150sg. remote is zenith CLO19
Necesito c?digo de control Philips universal clo19 para dvd Philips
The correct code may be 0177, 0247, 0441, 0442, 0447, 0598, 0599, 0699, 0799, or 0943.
Dec 11, 2016 | Philips Televison & Video
What is code for zenith tv?and how do I enter this on remote
If you are trying to use a Zenith remote to control your Zenith TV, the codes are in the remote so no entry is necessary. If your Zenith remote is not working, try replacing the batteries.
Mar 11, 2015 | Zenith Televison & Video
Have a Zenith DTT901 converter box, need the remote codes for my zenith remote, thanks
Your Zenith remote should be able to control your Zenith DTV box. If not, your remote may not have the latest codes or it could be defective. You may have to try a newer programmable remote.
Dec 10, 2014 | Zenith Dtt901 Digital Tv Tuner Converter...
Why cablevision remote won't work for zenith tv
The remote should be sync with Zenith TV; using its set-up codes.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Jul 31, 2014 | Televison & Video
Lost my remote for my zenith tv model #H2530Y
Remotes.com lists 2 remotes for the H2530Y. They do not have either of the original remotes in new condition. They have a used version of the Guest remote.
They also have the substitute remotes for both. The substitute Master remote (which will program the TV) is here: http://remotes.com/store/zenith/h2530y_master.html . The available guest remote is here: http://remotes.com/store/zenith/h2530y_guest.html . The substitute remotes should match all of the functions of the original equivalent remote.
I hope this helps.
Apr 26, 2012 | Zenith Televison & Video
There's no code for a Zenith DTT 901 to an RCA universal remote?
Hi.
Try this RCA code for Zenith -> 001
Regards...
/Tech5508
Feb 16, 2009 | Zenith DBZN-311 Remote Control
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
RCA tv and a zenith remote cl015
take a poop ans sculpt it into a new remote.
Oh, i would let it dry out in the sun for a couple days before attempting to sculpt, up to you.
Dec 01, 2007 | Radio Shack 3-in-1 Easy-to-Use Universal...
Zenith 350
Magnavox
103, 112, 113, 117, 119, 127, 128, 130, 139, 165
Zenith
101, 142, 149, 177
RCA DSS
373, 394
Zenith Satellite
312, 328, 330, 351
Nov 04, 2007 | Zenith ZN-501S Remote Control
Cannot access menu
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
Oct 01, 2006 | Zenith SY1931SG TV
Televison & Video Logo
13 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
