Question about HEALTHRIDER H55t Treadmill with Doorway Delivery - -
Healthrider H55t makes a clicking noise
When I start walking a clicking noise from the motor area starts. It gets louder the faster you go, but starts even at 1 mph. The belt seems to be straight... any ideas?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Check the front roller. Remove the drive belt and run the motor. If the noise is not there replace front roller.
Posted on Jan 04, 2014
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Posted on Jun 28, 2010
valeantudor
  • 787 Answers
SOURCE: My Healthrider s500i makes a
Try oiling that part for smoother function.
Posted on Feb 23, 2011
AJIN G
  • 6694 Answers
SOURCE: Healthrider S500i HRTL12990 belt won't run
HI,
If you can then before replacing the Motor control board do one thing. Replace the IGBT on the control board. Igbt is the component which drive the motor. It will not cost a lot. The only thing is you should be very careful while working on the motor control board because there you can see two capacitors which is capable of store charge for a long period of time even the treadmill is unplugged. Before doing work on the control board you have to discharge the capacitor. If not it will lead to serious electric shock. You will get many pages on web to know how to discharge an electrolytic capacitor. I have add the picture of the motor control board with the igbt marked. You can find the part number written in its frond side. Replace the IGBT first.
Ajin
Posted on Jan 19, 2012
ercupa190
  • 12223 Answers
SOURCE: Healthrider 500i. The screen lights up with no belt, fan, or key pad response. I manually started the belt then it wouldn't stop or change speed.
adjust the Reed Swith see the diagram:RESET, clean, and tight cable connector.
2) Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Posted on Aug 29, 2012
Noise inside is getting loud while cruising faster than 40mph
Hey Daniel
This all depends on what type noise... it is NORMAL for noises to get louder the older the vehicle gets, and faster the vehicle goes...the seals around the doors and the windows get old, develop leaks, and start to let air in....things do not fit as well as they did when the vehicle was new...as tires get older, they start to make noise also, the exhaust system is getting older too.. it starts to let more noise through.....
... I hope this helps you understand about age and noise...
Sep 25, 2017 | Cars & Trucks
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
High pitch noise sounds like bird in way
Have the accessory drive belt checked and the automatic tensioner for that belt.
Mar 24, 2014 | 1999 Chrysler Cirrus
Chevy engine noise
sounds like it might be a valves needing adjusted.does it do it when you first start it or after it gets hot?
Aug 21, 2013 | Oldsmobile Cars & Trucks
2005 mercury 9.9 hp bigfoot motor
does it get faster with speed the clicking ? could be a bearing !
Apr 28, 2013 | Mercury Four-Stroke Outboard Motors, Model...
Treadmill deck squeaking on left hand side
please do the following:
1) LUBE the deck belt , this happen because the lack of maintenance schedule.+adjust it each side see the diagram,worn deck probably.
2) Lube the rollers bearing too
3) test the motor for bearing need repair
4) test the drive belt for broken or worn.
5) test the puller for drive motor,can be worn, and replace.
God bless you
Jul 18, 2012 | Reebok Exercise & Fitness
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
While driving, I am hearing a continuous sound like a tire is flat; however, the sound only starts at about 20 mph, and it seems to get louder the faster I go. What could be causing this noise if the tires...
so hard to diagnose over the phone, however, you could try a couple of things, check to see if any of the tires are rubbing against anything. if not, can you try and distinguish where the sound in coming from? in the engine compartment, it might be something like a shredded belt, or it could be your u-joint...try those first, best of luck
May 30, 2010 | 1998 Chevrolet Tahoe
HEALTHRIDER H55t Treadmill with Doorway Delivery - - Logo
913 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Techmotionusa.com
Techmotionusa.com
Matty Piilo
Matty Piilo
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
