Question about Dakota Alert Wr-3000 xtra Wireless Receiver Wr3000
No alarm at reciver
Led lights up but no siganl set
How to set clock on musky
Unsure which model Musky. Example of DY28.
https://www.banggood.com/Musky-DY-28-Touch-Sense-Mini-Bluetooth-Speaker-TF-AUX-Colorful-LED-Light-Alarm-Clock-p-1084269.html?cur_warehouse=CN
Time Mode and Alarm Mode:
Press and hold MODE to enter the setting time mode, you can begin to set the time based on your local time.
In Alarm mode, long press MODE key to enter the setting alarm mode. Once you see a bell photo shines on the display, you can set alarm time as you need.
Musky DY 28 Touch Sense Mini Bluetooth Speaker TF AUX Colorful LED Light...
May 15, 2018 | Audio Players & Recorders
Why did the red flashing alarm light stop flashing? Alarm and remote working fine
Most likely the 12 volt led light burned out.. all bulbs LED too don't last.. Find the 2 wires usually Black and red and check for 12 volts with the alarm set and if you have 12 volts,. you need to go to radio shack and see if they still have 1. 2 volt led bulbs.. Good luck.
Oct 23, 2016 | Toyota Cars & Trucks
It ask printer absorver full, contact with service center
Canon waste ink full
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is not installed, the
carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green (Power) EEPROM information print
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
>>>> 4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings [hth: not applicable]
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Sep 01, 2010 | Office Equipment & Supplies
Waste ink absorber - what is it and how do we rep[lace it?
plz try
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
any changes.
Note : if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work.
Aug 26, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Printer reads "Waste Ink Near Full"
www.fixyourownprinter.com/forums/inkjet/50418
The above link will assist you.
any changes.
[hth: if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work. If anyone knows how to defeat this error, I would like to know.]
Aug 24, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Waste ink is full how do i fix it?
all is revealed above.
any changes.
Mar 29, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error 5B00 trying to get to service mode to reset waste ink code but need to bypass the alarm mode.
Hello there..
Here is how you fix this error:
any changes.
I really hope this can help you.
Best regards
Andrea
Oct 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
IR Receiver
Are you serious?
In case you are serious, IR=infrared.
When you point your TVs remote control toward the TV and press a button, it is the IR receiver on the TV which receives the IR signal which is transmitted from the IR LED (Light Emitting Diode), which is the small bulb like part, on the front end of your remote control.
Any device using a IR remote control, must have an IR receiver to gather the siganl being transmitted. The IR siganl is a coded message of instructions for the device.
Dec 08, 2007 | Jazz DV-179 Digital Camera
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
selectable.)
resume/Cancel button. (DO NOT release the Power
button.)
Power
in
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
not installed, the carriage returns and locks in the
1 time Orange (Alarm) Service test print .
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
to select the destination. For detail, see
"Destination settings procedures" below.
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Monitor screen blank and LED orange light flashing
For some reason, it seems as if your monitor has either lost the video signal or the capability to interpret the siganl. If you have the ability, put a second monitor (or tv) to your computer. See if you get a video siganl. If you do, then your monitor has an internal issue with the signal and needs to be addressed "hands on" by a technician. If you do not see a video, then your problem lies within your video card. Good luck.
Aug 18, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
Dakota Alert Wr-3000 xtra Wireless Receiver Wr3000 Logo
67 people viewed this question
Top Dakota Alert Home Security Experts
Lawrence Oravetz
Are you a Dakota Alert Home Security Expert? Answer questions, earn points and help others
