Question about Broderbund Calendar Creator 12 for PC
Add text box to weekly calendar so it prints on all pages
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
Tip
How to make a photo book ?
Normal 0 7.8 &#30917; 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:&#26222;&#36890;&#34920;&#26684;; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <p><span>Our photos are pieces of the fabric that makes our life the crazy patchwork quilt that it is. They are distinctive, they are unique, and they mean something special to us. So we need a way to make them together. If you really have such mind, why not make your own photo book? With a Photo Collage Maker you can easily create your own book .</span><br /> <p><span> </span><br /> <p><span>Photo Collage Maker is digital scrapbooking and photo collage software. It allows you to create and print scrapbook layouts quickly and easily. Automate your work with compositions, enhance photos with effects, spice up your creation with borders, frames, backgrounds and clipart. With just a few clicks, you can create collages, scrapbooks, posters, invitations, calendars, and greeting cards. Unlike photography software that takes days to master, <a href="http://www.photo-collage-maker.com/">Photo Collage Maker</a> lets both seasoned collagers and new hobbyists become productive in minutes. Following is the step by step tutorial on how to make a photo book.</span><br /> <p><span> </span><br /> <p><span>Step 1 - Add your photos to the Project</span><br /> <p><span>In the Photo Pane on the left, find the folder where the photos you want to add are located and the photos will be shown in thumbnails list below, then just drag each photo in thumbnails list to your collage or double click it. Btw, you can adjust the photos by resizing and rotating them.</span><br /> <p><span> </span><br /> <p><span>Step 2 - Adding Text &amp; Clipart to project</span><br /> <p><span>On the Collage menu, click Add Text to add text your collage. To get the best effect, you can set the font and color of the words to be added as you wish.</span><br /> <p><span>Open Clipart Pane .You can see the list of Cliparts in the left part of Picture Collage Maker window. Double click a clipart to add it to the current project. There is an assortment of images for you to make choices.</span><br /> <p><span>PS: In this step, you can also adjust the text and clipart by resizing and rotating with the dragging of the mouse cursor.</span><br /> <p><span> </span><br /> <p><span>Step 3 - Apply background patterns to collage</span><br /> <p><span>Open Background Pane and Double click a background to apply it to the current collage.</span><br /> <p><span>Apply background patterns to collage.</span><br /> <p><span> </span><br /> <p><span>Step4 - Add New Page</span><br /> <p><span>On the very right part, you can see a Page Pane, now please click "add page", a new blank page will be created. Want to edit it? Yes, we can just go ahead to edit the page just by clicking the new page. In this way, we can create pictures on and on as we wish.</span><br /> <p><span> </span><br /> <p><span>Step5 - Save Project as JPEG file or print</span><br /> <p><span>On the File menu, click Save Collage as Picture and specify a folder on your hard disc to save current collage project as a image file. Or you can choose Print Preview on the File menu, and print the photo book you've just made.</span><br /> <p><span>The steps are not difficult , only a few minutes , </span><span>the conversion will be finished. </span><span>Photo Collage Maker is a powerful tool , with it , you can not only make a photo book , but also <a href="http://www.photo-collage-maker.com/guide/create-photo-collage.html">create photo collage</a>. It is also a good way to restore your happy moment .</span><br />
on Oct 26, 2010 | Computers & Internet
Tip
Keep your ink-jet printer printing
Print head or ink cartidge clogged? Prevent this common problem. If you don't use your ink-jet on a regular basis, opting to use a laser for faster printing and sharper text, pick a day of the week (anyday) and make an entry into whichever calendar application you use to send a recurring reminder to print a test page from your ink-jet. Printing at least once a week will reduce the possibility that the cartridge or print head will clog with dry ink.
on Jun 13, 2010 | Office Equipment & Supplies
Hi! I am having a problem editing page numbers in adobe
Rotate the page before inserting a box for the page number. You have to use the Forms function to insert a box and add the page number. Then Rotate back. Then print the form to PDF. When you open page number will be where you placed it.
Nov 24, 2009 | Adobe Acrobat Professional 7.0 for PC
Tip
Prinshop 23 Deluxe, fix character banner display in calendar
This is a fix easier explained than titled...
When using Calendar Creator in Printshop 23 Deluxe you can add multiple events across multiple days. But while a single event can use box, when adding multiple events it cuts off the message so many use banner to get them in the box for that day. The problem is that when you print, although the box event prints fine, the banner events will cut off part of the last character on the right side. This effects any character including space, so to fix this; just add a space at the end of each event you're importing.
on Mar 22, 2010 | Computers & Internet
How do you type inside a microsoft powerpoint slide?
default.aspx?assetid=za790050001033Show All default.aspx?assetid=za790050011033Hide AllDo one of the following:
default.aspx?assetid=za790050011033Add body or title text
Note If your text exceeds the size of the placeholder, Microsoft PowerPoint reduces the font size and line spacing incrementally as you type, to make the text fit.
default.aspx?assetid=za790050011033Add text to an AutoShape
Note To add text to a line, connector, or freeform (freeform: Any shape you draw by using the Curve, Freeform, and Scribble tools. Freeform shapes can include straight lines and freehand curves. They can be drawn opened or closed and can be edited.) AutoShape, you must add text using a text box.
default.aspx?assetid=za790050011033Add text to a text box
  1. On the Drawing toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Text Box default.aspx?assetid=za060447551033.
  2. Do one of the following: default.aspx?assetid=za790050011033Add text that stays on a single line
    default.aspx?assetid=za790050011033Add text that wraps
    I hope this helps
Oct 27, 2009 | Microsoft Windows Vista Home Premium with...
I need a 6 month calendar on one page portrait.I would like to be ablet to insert text in the day boxes using word and I don't need Sat and Sunday. I have vista home premium. herbert.chavkin@gmail.com
MSWORD has templates for calendars on its Office website.Otherwise create your calendar with TABLE option.
Set up SEARCH CALENDAR MSTEMPLATES in your browser.
Please rate the help++++Thanks for using FIXYA
Sep 25, 2009 | Computers & Internet
Prints Blank Pages
Hello !!
Thank you for posting your question at FixYa.com
It seems like, it's a problem with the Software from where you are trying to print & for sure not your printer & to make sure it's not the printer follow this.
1. Start -> Run -> Notepad
2. In the notepad, Type some text & save it on your Desktop.
3. Try to print out from the Printer.
Hope this will help you figure out the problem, also feel free to revert with the Software details & I'll be more than happy to assit you with that as well.
Regard's
Anurag Shukla
Sep 02, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Broderbund Calendar Creator 12 for PC Logo
27 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
