Question about Sony Ericsson K500i Cellular Phone
I have a landrover s1 sonim phone trying to find drivers to work
Tried a number of drivers they dont load
  • e cargill
    e cargill Jan 03, 2014
    when i try to down load the driver for the landrover s 1 xp3 mark 2 it is saying no drivers can be found or down load does not complete
I bought my son a sonim XP 3400 and can't find any parental control or cell tracker software that is supported please help!
Only Smart Phones have those options. Regular phones only have what is loaded on them when you buy them.
Oct 06, 2014 | Cell Phones
How to change ring tones on sonim xp 1520 bolt sl
go to menu then phone settings then profiles then headset then tone settings ....enjoy
Jul 04, 2013 | Cars & Trucks
HELP my new sonim locked me out while I was trying to create password.. My IMEI is 35169603-111206-3 Missing lots of work calls Andre Miller
All you need to do is contact your phone provider for an unlock code to this issue. If your unable to contact them, you may download an approved list from the internet to use while attempting to unlock the cell phone again.
Jan 21, 2011 | Sendo Sonim XP1 JCB phone extreme...
I have a JCB mobile phone , when l switch it on l get a screen showing a key next to a lock , at the top of the screen it says Enter PUK1 , and a bar where it is possible to type up to 8 numbers or...
Hi, the PUK code is the security code for the sim card and not the phone, now when the sim card was new you would have been given the unique PUK code written on the card the sim card was attatched to.
if you no longer have this card then the only other place you can get this code from is your service provider, all you need to do is call them and give them either the phone number of the sim card or give them the number written on the back of the sim card, they will give you this code over the phone for free.
the other option you have open to you is if you dont need to use the sim card thats asking for the PUK code then you can go out and get another sim card and this will come with its own unique PUK code.
please dont try guessing the PUK code as it can be up to 11 digits long and they are totally random so guessing is beyond the question
let me know how you get on or if you need further assistance ok
please can you rate this solution, thanks..
My Sonim XP3 Quest Pro write sometimes fileerror.return when I have an incoming call up and it is not ringing
Hi Riisbjerg, you could try to reset/clear flash the phone. That should take care of the problem, but it also erases ALL settings and phone book entries from the phone, so it is best to make a backup of the phone bookwith the PC tools software.
The software can be downloaded from http://www.sonimtech.com/support/downloads.php
Reset: Please try to reset the handset memory as below:
a. After Powering ON the phone
b. press #20070114# from phone idle screen and press dial key.
c. Message comes up as " Do you really want to clear flash? "
d. Select OK. After reset is finished, you can see the message "Switch off the mobile by any keys".
e. Switch the phone off, then remove and reinsert the battery and Power ON the phone.
Once done, please restore the handset to factory settings:
a. Power the handset on
b. Using the menu buttons, go to Settings (General Tab) -> Default Settings.
c. Press the OK button to confirm
d. Power the handset on again
If this does not help, please send an email to the Sonim support team: support@sonimtech.com
Thanks!
Andreas Sonim Customer Service
Jan 15, 2011 | Cell Phones
On my phone i can hear the caller but thay can not hear me it is a sonim xp1
when you call someone and they don;t hear you,it means that the mouth piece which is located at the bottom of the phone and allows people to hear is faulty and will need to be replaced.
When you replace the mouth piece, people can now hear you.
Take care.
Aug 04, 2010 | Sendo Sonim XP1 JCB phone extreme...
How to unlock sonim xp1 mob phone.
Hello,the truth is that you can unlock the phone ,but you can't unlock all phone for free.The payment sites are very cheap you could try it out and see.You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can get a free unlock code.
Visit the links below if you are interested in buying the unlock code:
(hubpages.com/tag/cell+phone+unlocking/hot)
and
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
May 07, 2010 | Sendo Sonim XP1 JCB phone extreme...
How can i set my sonim phone so i can send and
Hi,am sure it's related to your sim card (network), not your samsung cell phone. In most cases, regarding mms messages, the problem is from the Service Operator. Have you tried the sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in vise versa by inserting another sim card on your mobile.
If you can't receive mms messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
if the same sim card doesn't receive mms messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
Have a nice day.
Apr 15, 2010 | Sendo Sonim XP1 JCB phone extreme...
How do you set up gps on sonim s1 phone all i keep getting on screen is start & save
Call your service provider and they will send you a settings for free.
Sep 19, 2009 | Cell Phones
Sony Ericsson K500i Cellular Phone Logo
75 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
