Question about Marantz SR4001
Marantz sr4001 receiver goes into protect mode only when i have the dolby digital input selected on my receiver and when the volume is at about -27db it will go into protect mode any advise would be
It goes into protect mode when the dolby digital input on the receiver is selected and volume is at atleast -25db. If it is at a lower volume it works perfectly fine its when the major sound effects occour that the receiver goes into protect mode
    Genius:
  • Marantz Master
  • 1,054 Answers
Sounds like a bad speaker. Do you have more than one speaker hooked up to a single output?
Posted on Jan 02, 2014
5 Suggested Answers
watsonhellas
  • 774 Answers
SOURCE: Marantz SR5000 Protect mode
The Marantz SR5000 and others of it's make, design type, and year group are prone to this problem. Many such units can be reset by pressing a sequence of three buttons with sporadic results... the SR5000; however, does not provide any such option. If the "Auto protect" mode comes "on" then you know it's not a simple power supply "fuse" problem that can be fixed for a dollar by opening the case and replacing the glass fuse with one of the same rating value that is stenciled on to the power supply circuit board. (Easier than trying to read the old fuse.) If you can get the schematics and know a bit about replacing electronics parts using a low-power soldering iron, then you might want to take a shot at fixing it; otherwise, it's time for recycling. (Tip: Look for discolouration on a part on a circuit board first, this indicates overheating and a possible short. Then trace the schematic circuit for the "Auto Protect" circuit to diagnose which integrated circuits is at fault.) Typically, it costs more to fix it in a commercial shop than it's worth as someone has to pay the cost of benchtime diagnostics... the repair part is fast once the faulty parts are discovered. There are free sources on-line of the service guide for this receiver; however, downloading the plethora of rar files to assemble a complete manual is a challenge.
Posted on Jul 09, 2012
cyrylthewolf
  • 143 Answers
SOURCE: Problem with Marantz SR5500 Receiver
Sounds like you have an issue with your electrical circuit. Your receiver could be receiving spikes of current from the electrical wiring in your house.
Review your current electrical situation. Keep in mind that certain outlets are on the same circuit and that running multiple, high-wattage devices on the same circuit can cause issues with some of those devices. Especially when it comes to turning devices on and off.
Many devices take a sudden, rapid charge to power their circuitry the moment you turn the device on. Home audio and HVAC systems are particularly notorious for doing this. Other devices on the same circuit can sometimes suffer influxes of power flow and may either turn off or go into standby mode to protect themselves from the resulting surges.
I've lost audio systems that way... I lived in an apartment building that has wiring most likely dating back into the 40's. I once turned on a space heater on it's max 1500 watt setting and blew my Logitech Z-680 speakers. (The "BOOM" sound that emitted from my subwoofer was AMAZING. I had just blown an amp circuit. It literally exploded inside of the subwoofer. Took pics and everything.)
If you have the means to do so... You might consider re-wiring your electrical circuit. Take into consideration where you're going to run certain devices and wire the system accordingly.
In the meantime, you would want to be sure to buy a HIGH-QUALITY surge protector for the audio system. Spend a few bucks and get a GOOD one with a good warranty on it. Don't use those cheapy ones that we only really use to split the outlet. NOTHING under 1,000 joules.
My receiver sometimes locks itself like that, though. If we have a power outage or the unit is unplugged suddenly, it will keep itself in standby mode until you unplug it, press the power button a few times to discharge any current left in the capacitors and plug it back in normally. Only then will it turn on again.
Let me know what you come up with.
Cyryl
Posted on Nov 03, 2007
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
  • 163 Answers
SOURCE: Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Posted on Aug 15, 2009
How to reset marantz sr4001 from protect mode?
Protect mode comes into play when there is a problem with the speakers or amplifier First check all the speakers for opens or shorts If they are fine you don't reset it you repair the receiver.
Aug 07, 2014 | Marantz Audio Players & Recorders
I have a Marantz SR 8001. The front display lights went completely out, but the blue lights over the selector knob, volume knob, and the HDMI blue light comes on. I was setting up a Logitech 1100 remote...
You have a nice piece of Stereo...I believe you have mistakenly selected the" display mode OFF" function..,Here is the info that you can reactivate it..
If you need a soft User Manual here is the link for it too..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)...please insert some words in "
My Testimonials "
Hope this helps!
" display mode OFF"
You can select the display mode for the front display
of the SR7001.To select this mode, press the DISPLAY on the remote control or the front panel.When this button is pressed, the display mode is switched in the following sequence.Input Mode ? Surround Mode ? Auto display OFF ? Display OFF ? Normal Mode ? Input Mode Normal Mode: Displays the selected input function. If the function has been renamed using the Function Rename feature (see page 26), the renamed name appears on the display. Input Mode: Displays the input mode set via the Function Input Setup feature (see page 25). Surround Mode: Displays the status of the selected surround mode. Auto Display Off mode: The display is off. But, if you make a change to the unit such as the input or surround mode, the display will show that change, then go back to off after about 3 seconds. When changing the volume, it is not displayed. Display Off mode: The display is off completely. Note: • Only the DISP indicator will be illuminated on thefront display in display off condition
http://www.scribd.com/doc/53431794/Marantz-SR-8001-Owners-Manual
Jun 23, 2011 | Marantz SR8001
How do you connect an ipod/ipad to the Marantz sr4001
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 24, 2011 | Marantz SR4001
My Marantz sr 4001 receiver has no output. Is
There is no fuses for the speakers. Check setup. If the receiver has 7.1 channel input try to connect a source there so you can check output (amp) section and the speakers.
Jul 18, 2010 | Marantz SR4001
Panasonic SC-PT660 digital in doesn't work
Select to suit the type of audio from the OPTICAL IN terminal on the main unit.
1 While in “D-IN” mode
Press and hold [—SETUP] to select “MAIN/SAP”, “DRC” or
“PCM FIX”.
2 While the selected mode is displayed
Press [up, down] to make the setting.
MAIN/SAP mode (Only works with Dolby Dual Mono)
MAIN, SAP§, MAIN+SAP§ (stereo audio)
§ “SAP” = Secondary Audio Program
Dynamic Range Compression
DRC ON: Adjust for clarity even when the volume is low by compressing
the range of the lowest sound level and the highest sound level.
Convenient for late night viewing. (Only works with Dolby
Digital)
DRC OFF
PCM FIX mode
PCM ON: Select when receiving only PCM signals.
PCM OFF: Select when receiving Dolby Digital and PCM signals.
[Note]
Audio that is input through the OPTICAL IN terminal cannot be output
through the HDMI terminal.
Nov 29, 2008 | Panasonic Home Theater System System
No sound/data from dvd or tv to receiver( marantz sr4001).. tuner works as does aux where i run my mp3 from. have just rehooked up main and center channels after repair. nothing else has changed ..just no...
You may have to tell the amp which type of input the dvd and tv are pluged into eg phono,optical or coax,you should find this in the amp set up menu.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Marantz Audio Players & Recorders
Onkyo receiver TX-DS696
If you get sound on direct mode say from dvd but no sound when you go to dolby make sure you have the right input selected by pressing the digitat input button on the front of the amp,ie if dvd optical out is pluged into amp optical input 1 select this on amp then set audio to prologic2.DVDs through this input will decode to dolby digital/dts.
hope this helps.
CABLE GUY.
Jun 25, 2008 | Audio Players & Recorders
Hook up your Xbox to a Dolby Digital Decoder
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Marantz SR4001 Logo
317 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
