Question about Microsoft Wireless Race Wheel 2 for Xbox 360
Pedals broken on xbox 360 MS wireless wheel
Pedals broken on xbox 360 microsoft wheel.. There was something rattling inside so I undid 12 of the 14 screws (other two are sealed behind serial number sticker) and a small metal contact tab fell out which looks like it's broken.. Any clues how I could fix this? I don't think its still under warrantee so would MS fix it for small fee?
  • 2 more comments
  • norman1nz May 21, 2009
    do you know what the internals of pedal box look like?
    I was thinking it might be easier to use some kiwi ingenuity and solder / repair it myself than wait weeks or months for MS to fix it (and probably charge more to do so than I could buy another secondhand wheel for)
  • norman1nz May 29, 2009
    I called M$ support New Zealand and they said as the wheel is out of warrantee they can't fix it (not even if I paid them), nor could they supply another set of pedals...
    So now I've got a paperweight wheel unless I can find another set of pedals..
    Are there other cheaper wheels with compatible pedals (using RJ11 plugs) I could use (I know logitech 360 wheel has a VGA plug)..
    Or is there any way I can try fixing this myself? I've got nothing to lose by trying...
  • norman1nz Jun 21, 2009
    bump.. Getting pedals repaired by MS is not an option unfortunately
    yes thats the wheel - however i onlly need another set of pedals..
    I have a logitech FX wheel for 360, which has VGA cable to pedals - is there any way i could convert this vga cable / plug into rj11?
I've see a lot of posts where people have had issues with the Microsoft racing pedals not working properly. Usually the throttle just races away when it is suppose to be at idle. I had this problem and after taking apart the pedal set more than once to try and fix it - it's made so cheaply - I gave up.
So, if you want a good fix, here is what I did. I got a set of Madcats 2 pedals, which are X-box compatible (craigslist) - other pedal sets may work but then you would have to figure out the wiring on your own which took me considerable time NOTE: These do not have to be the Madcats pedal set from the force feedback type, just the standard pedal set will work.
I went to home depot and bought a wall phone jack. I then took the bottom off the Madcats pedals (the Phillips screws are under the square rubber pieces which you can peel off with a small blade - common screwdriver) and you will see there are 4 wires going to the cable that normally plugs into the MC2 wheel. Pop the face plate off from the phone jack but don't throw it away and cut the cable on the inside of the MC pedal set about 2" from the grommet. You can pull the grommet out of the slot and discard the cable. Carefully strip the insulation on the 4 wires (Brown, Yellow, Blue and White). I've done the hard part, which took me about 5 hours so here are the correct wire color match-ups. The phone jack has Green, Black, Red and Yellow wire hook-ups. Connect the MC-Yellow to PJ-Green; MC-Blue to PJ-Black; MC-Brown to PJ-Red;MC-White to PJ-Yellow. Now you can plug in the phone wire connection from the wheel into the phone jack and try out the MC Pedals. Much better? What I did next was cut a hole in the back of the MC pedal case (make sure it is not in-line with where the bottom plate weight goes. I used a hole saw just smaller than the phone jack and then used a razor knife to form a good fit fro the phone jack. Remember the face plate? Get yourself a good pair of sturdy Scissors and cut around the circle on the face plate. Now put the phone jack in the hole you made from the inside of the pedal housing and snap that little disk you just cut out from the face plate onto the phone jack from the outside of the pedal base. Now you may want to glue the phone jack in place on the inside of the pedal base just so it stays put. I used epoxy putty because it kneads like play-do and is easy to push on place. Also it sets up in just a few minutes. Now just put the bottom plate back on the MC pedals and put the screws back in. You will find that the MC pedals do not have the same problems that the Microsoft pedals did like the sticking throttle problem and they are much more responsive.
Posted on Jul 08, 2012
  • 6,784 Answers
HI, the best solution for this issue is to allow Microsoft to repair this wheel assembly. the linkage seems to be broken inside the assembly and the parts needed are not available for consumer purchase. only MS can repair this device.
Posted on May 20, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters May 21, 2009
    You stated that that there was a piece that fell out of the assembly, if this is the case, you will need to have it repaired. this vital piece is part of a mechanism that will need to be complete in order to function correctly.
    The integrity of this design has been compromised by this separation contact metal tab(link). If you solder it or patch it up, it may not last very long.
    And, yes. i do know what it looks like inside:)
  • Michael Masters
    Michael Masters Jun 21, 2009
    HI again. try this link. i think this one should work. let me know if this wheel is not the actual wheel you are looking for. i have other links.
    Click here.
  • Michael Masters
    I actually thought you may ask that question so, i searched for an adapter to no avail. There are no adapters at this time that could meet your needs unfortunately.
My Xbox 360 isn't recognising the Madcatz wireless steering wheel and pedals.
You have to connect them like you would a new remote , first press the connect device on console then do the same for mad cats you want to connect.
Nov 30, 2014 | Video Game Consoles & Games
I have the Wireless Racing Wheel with Force Feedback. We usually play Forza Motorsport 2 and everything worked fine. We recently bought Need for Speed Hot Pursuit (2010) and the pedals don't work. ...
Hello, NFS Hot pursuit 2010 on the Xbox 360 officially supports the Microsoft wheel but any Xbox 360 wheel will most likely work fine....their words. I haven't played the console version but if you say the wheel works I suggest you try remapping the pedal controls under gameplay settings if this is possible
I hope this helps, thanks for using FixYa.
Sep 02, 2011 | Microsoft Wireless Racing Wheel for Xbox...
My steering wheel works but my pedals don't work. How can i fix this?....also, I can only select reverse with the left paddle, and then be unable to select any other gear... thnaks ....newbie.
Mine to I'm currently arguing wiv the guy I bought it off on eBay. Apparantly theirs a battery inside the wheel but I Can't find it. Theirs a battery pack on the side but mines fine. If u have worked it out let me know will ya silentnightingale@hotmail.co.uk
Jan 16, 2011 | Microsoft Wireless Racing Wheel for Xbox...
Xbox 360 Steering wheel - Pedals squeak - what sort of lubricant to use please?
I've been using wd-40. This is my second time using it in about 1 to 2 years. I just need to figure how to eliminate squeaks in the wheel. Good luck!
Oct 18, 2010 | Microsoft Wireless Racing Wheel for Xbox...
Racing wheel setup
OK, at least for my issues, after talking to MS support ...
Here was the issue with the Setup disc (Forza Demo): If it jumps into the demo ... the XBOX DOES NOT need to be updated.
As for not connecting to the XBOX (Sync'ing up the controllers) ...
You need to press the SYNC (located by the memory card slots)Button BEFORE you PRESS the SYNC button on the wheel controller. Once you do that (a step that is not clearly pointed out in the stupid an poorly written manual) all worked asa expected. A Simple hook-up procedeure that took 2 days because of a step that was not pointed out or not made obvious to the XBox Parents and non users.
Dec 25, 2008 | Microsoft Wireless Racing Wheel for Xbox...
Right joystick
I don't personally know of anywhere that will replace the stick. If it truly is broken as you say, you will need to purchase another one. After all, it is broken.
Nov 11, 2008 | Microsoft MS Xbox 360 Common Controller...
Wireless steering wheel for Xbox 360
that function only works when its cables are hooked up...
Aug 13, 2008 | Microsoft Xbox 360 Console
Microsoft Wireless Race Wheel 2 for Xbox 360 Logo
725 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
