Question about Ultraviolet Heat Shield Covers For Causes for a Volkswagen Rabbit
My 2007 charger is missing and shuts down after short period
My dash-3-5 bad code om my 2007 charger says I have cylinders 6-3-5 showing as not working
    Habit-Forming:
    Scholar:
  • 169 Answers
Sometimes the problem could be as simple as an improperly set spark plug. Take a look at the Attached video link to learn more about Detecting A Misfire. https://www.youtube.com/watch?v=m2fubKkvZVI You should also keep in mind that your problem could also be a faulty Fuel Injector.
Posted on Jan 02, 2016
    Scholar:
  • 88 Answers
If 1 cylinder misfires it will throw a multiple misfire codes. It is probably a defective coil or injector in one cylinder. When one cylinder has poor combustion compression is affected on other cylinders they will then lose power on the combustion downstroke.
Posted on Feb 15, 2015
    Sergeant:
  • 384 Answers
O to autozone have the code read and it will tell u whats up
Posted on Jan 04, 2014
Have changed all plugs and coil packs but still giting miss in 1 3 5 cil think its a short in wire hornins but cant find a diagram
If you are getting a misfire code on those three cylinders (all on just that one bank of engine!), it's probably not an electrical short, but something else causing misfire. Misfire codes are set when the power output from that cylinder is less than expected: the pcm senses a crankshaft lag in power output and sets the code.
Typically, misfires are caused by weak or missing spark, or by fuel/air mixture problems, or by low cylinder compression. The fact that your misfires are all on one bank (side) of the engine sounds suspiciously like the fuel/air mixture might be wrong for that bank, or the cylinder compression is low on that bank.
You could use a spark tester just to check spark on 1, 3, & 5. Use a calibrated spark tester to compare both banks-all 6 cylinders. I think you will see equal spark at all cylinders. The only shorts would be in the spark plug wires. And not likely all 3 went bad at once, although you could check them, maybe swap a few around and see if the misfire follows the wire.
Start looking for air or vacuum leaks that only affect bank 1. Possibly an intake manifold leak, could also be an exhaust leak, something that affects the air/fuel mixture in the bank 1 cylinders. Also you could do a compression test of the cylinders to make sure bank 1 is good, same compression as in bank 2 (the other side of engine). Just some tips to help you out, good luck.
Feb 20, 2016 | Cars & Trucks
GMC Yukon has code C0561 stability/ traction comes on
Could be bad coils on 3&7,if not can be module,try to swap coils if will show the same number that mean MODULE.
Jan 10, 2015 | 2007 GMC Yukon
HAVE NO SPARK OUT THE COIL
nov 6, how'd i miss this..???
not the V6 , right?
as always, check all fuses. (op guide in glove box shows em)
ok the car (USA) has a EFI system with spark too.
this EFI system has 3 parts to make spark. (not counting coil)
crank sensor (the ECU will flash a code if dead, did you looK).
ECU (unliikely but do check the DTCs lamp codes)
Dizzy
Coil.
Got code (DTC) 4,8,9,15, ah bingo?
here are the words in the FSM ( got one yet , they are free too)
On 1990-95 Accord (except V-6) and 1992-95 Prelude, the codes are read from the check engine light after the two-wire service connector has been jumpered. On Accords, the service connector is under the dash on the passenger side. On Preludes, it is located behind the center console. Codes 1 through 9 are indicated by a series of short flashes; two-digit codes use a long flash for the first digit followed by the appropriate number of short flashes. For example, Code 14 would be indicated by 1 long flash followed by 4 short flashes. Codes are separated by a pause between displays. Multiple codes are transmitted in an alternating pattern. For example, a code 3 and 14 would be displayed as 3 short flashes (for Code 3) followed by the separator pause, then 1 long flash and 4 short flashes (for Code 14).
end quotes
or RTM? here. free, its all there.... even simple coil tests.
but id bet its not the coil, for sure i dont know, i only tests. and then replace truly bad parts.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 06, 2013 | 1991 Honda Accord
2007 rav 4 check engine , vsc, 4wd dash lights all came on at once?
This happened to me last year. Coil 6 went bad, but since I drove it for a while like that, it was causing other cylinders to misfire. When I had it scanned, it said all 6 had misfired. I would have your CEL reset and once you have the next misfire, immediately get the code off the car. This should help pinpoint which coil went bad. Odds are, coil 4 or 6 is the culprit, those fail the most due to excessive heat from the radiator.
Jun 12, 2012 | 2007 Toyota RAV4
What sensor would cause my 2007 Mazda R/X8 to show trouble code P206 to show up?Service engine light came on and after a day it went off.
  • A P206 is a failed injector in Cylinder 6.
  • Other possible causes are an opening or a short in the wiring to that injector or a bad PCM.
  1. First take a multi-meter and test for resistance within specs.
  2. Check for 10 volts or move at the injectors connector.
  3. Inspect the injector wires for rips,cracks,tear, melting etc.
  • Hope this helps and thank you for using FixYa
Regards, Tony
Jun 16, 2011 | 2007 Mazda RX-8 Touring Sedan
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
SHUTS DOWN AFTER A SHORT PERIOD OF TIME. GREEN
this is a technical problem.have someone professional come and take a look.
Jun 15, 2010 | Heating & Cooling
Ultraviolet Heat Shield Covers For Causes for a Volkswagen Rabbit Logo
154 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
ptpumpman
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
